Hello,I need to cancel last vertex drawn using Draw toolbar with geometry types POLYGON or POLYLINE and do not interrupt drawing process (geometry should be redrawn).I implemented it like this:
var dt = drawToolbar; // NOTE: from somewhere
var points = dt._points;
if (points.length > 1) {
var geom = dt._graphic.geometry;
geom.removePoint(0, points.length - 1);
points.splice(points.length - 1, 1);
dt._graphic.setGeometry(geom);
var start = points[points.length - 1];
var tempGeom = dt._tGraphic.geometry;
tempGeom.setPoint(0, 0, start.offset(0, 0));
tempGeom.setPoint(0, 1, start.offset(0, 0));
dt._tGraphic.setGeometry(tempGeom);
} else {
dt._points = [];
dt._onMouseMoveHandler_connect.remove();
dt._clear();
But as You can see, it uses private attributes. It would be nice, if ESRI would implement this functionality in later releases, because it's really useful, I think. Maybe someone has an idea how to avoid using privates?
