private function sfDataGrid_Click():void { var obj:Object = sfDatagrid.selectedItem; if (obj != null) { var polyExtent:Extent = new Extent(obj["XMIN"],obj["YMIN"],obj["XMAX"],obj["YMAX"]); lastIdentifyResultGraphic = null; // this section will highlight the feature selected sfQuery.where = "Name = '" + obj["Name"] + "'" sfPolygonQueryTask.execute(sfQuery, new AsyncResponder(onResult, onFault)); function onResult(featureSet:FeatureSet, token:Object = null):void { lastIdentifyResultGraphic = featureSet.features[0]; lastIdentifyResultGraphic.symbol = sfsOutline; } function onFault(info:Object, token:Object = null):void { Alert.show(info.toString(), "Query Problem"); } MainMap.extent = polyExtent; if (!MainMap.extent.containsExtent(polyExtent)) MainMap.level--; } }
TypeError: Error #1034: Type Coercion failed: cannot convert com.esri.ags::Graphic@5c8a0b1 to com.esri.ags.layers.GraphicsLayer. at testing/private:sfDataGrid_Click/onResult() at mx.rpc::AsyncResponder/result() at com.esri.ags.tasks::QueryTask/handleDecodedObject() at Function/http://adobe.com/AS3/2006/builtin::call() at com.esri.ags.tasks::BaseTask/handleResult() at <anonymous>() at mx.rpc::Responder/result() at mx.rpc::AsyncToken/http://www.adobe.com/2006/flex/mx/internal::applyResult() at mx.rpc.events::ResultEvent/http://www.adobe.com/2006/flex/mx/internal::callTokenResponders() at HTTPOperation/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent() at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::resultHandler() at mx.rpc::Responder/result() at mx.rpc::AsyncRequest/acknowledge() at DirectHTTPMessageResponder/completeHandler() at flash.events::EventDispatcher/dispatchEventFunction() at flash.events::EventDispatcher/dispatchEvent() at flash.net::URLLoader/onComplete()
<?xml version="1.0" encoding="utf-8"?><mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Query, then zoom to results" styleName="plain"> <mx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.geometry.Polygon; import com.esri.ags.tasks.FeatureSet; import mx.controls.Alert; import mx.rpc.AsyncResponder; private function doQuery():void { queryTask.execute(query, new AsyncResponder(onResult, onFault)); function onResult(featureSet:FeatureSet, token:Object = null):void { // clear the graphics layer myGraphicsLayer.clear(); if (featureSet.features.length == 0) { Alert.show("No States found. Please try again."); } else { var unionExtent:Extent; var myFirstGraphic:Graphic = featureSet.features[0]; unionExtent = Polygon(myFirstGraphic.geometry).extent; for each (var myGraphic1:Graphic in featureSet.features) { myGraphicsLayer.add(myGraphic1); unionExtent = unionExtent.union(Polygon(myGraphic1.geometry).extent); } MainMap.extent = unionExtent; } } function onFault(info:Object, token:Object = null):void { Alert.show(info.toString()); } } private function sfDataGrid_Click():void { var obj:Object = sfDatagrid.selectedItem; if (obj != null) { var polyExtent:Extent = new Extent(obj["XMIN"],obj["YMIN"],obj["XMAX"],obj["YMAX"]); myGraphicsLayer = null; // this section will highlight the feature selected query.where = "STATE_NAME = '" + obj["STATE_NAME"] + "'" queryTask.execute(query, new AsyncResponder(onResult, onFault)); function onResult(featureSet:FeatureSet, token:Object = null):void { myGraphicsLayer = featureSet.features[0]; myGraphicsLayer.symbol = sfs; } function onFault(info:Object, token:Object = null):void { Alert.show(info.toString(), "Query Problem"); } MainMap.extent = polyExtent; if (!MainMap.extent.containsExtent(polyExtent)) MainMap.level--; } } ]]> </mx:Script> <!-- Start Declarations --> <!-- Symbol for Query Result as Polygon --> <esri:SimpleFillSymbol id="sfs" alpha="0.7" color="0xFF0000"/> <!-- Layer with US States --> <esri:QueryTask id="queryTask" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"/> <esri:Query id="query" text="{fText.text}" returnGeometry="true" outSpatialReference="{MainMap.spatialReference}"> <esri:outFields> <mx:String>MED_AGE</mx:String> <mx:String>POP2007</mx:String> </esri:outFields> </esri:Query> <!-- End Declarations --> <mx:HBox width="100%" height="40" backgroundColor="0xDDDDFF" paddingTop="10" horizontalAlign="center"> <mx:Text text="Search for U.S. States:"/> <mx:TextInput id="fText" enter="doQuery()" text="Ca"/> <mx:Button label="Query" click="doQuery()"/> </mx:HBox> <mx:Text id="resultSummary" height="15"/> <mx:VDividedBox height="100%" width="100%"> <esri:Map id="MainMap"> <esri:extent> <esri:Extent xmin="-126" ymin="24" xmax="-67" ymax="50"> <esri:SpatialReference wkid="4326"/> </esri:Extent> </esri:extent> <esri:ArcGISDynamicMapServiceLayer url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StateCityHighway_USA/MapServer"/> <esri:GraphicsLayer id="myGraphicsLayer" symbol="{sfs}"/> </esri:Map> <mx:DataGrid id="sfDatagrid" click="sfDataGrid_Click()" dataProvider="{queryTask.executeLastResult.attributes}" scroll="true" width="100%" height="40%"/> </mx:VDividedBox></mx:Application>
<?xml version="1.0" encoding="utf-8"?> <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Query, then zoom to results" styleName="plain"> <mx:Script> <![CDATA[ import com.esri.ags.geometry.Extent; import com.esri.ags.Graphic; import com.esri.ags.geometry.Polygon; import com.esri.ags.tasks.FeatureSet; import mx.controls.Alert; import mx.rpc.AsyncResponder; [Bindable] private var lastIdentifyResultGraphic:Graphic; private function doQuery():void { query.text = fText.text query.where = "" queryTask.execute(query, new AsyncResponder(onResult, onFault)); function onResult(featureSet:FeatureSet, token:Object = null):void { // clear the graphics layer myGraphicsLayer.clear(); if (featureSet.features.length == 0) { Alert.show("No States found. Please try again."); } else { var unionExtent:Extent; var myFirstGraphic:Graphic = featureSet.features[0]; unionExtent = Polygon(myFirstGraphic.geometry).extent; for each (var myGraphic1:Graphic in featureSet.features) { myGraphicsLayer.add(myGraphic1); unionExtent = unionExtent.union(Polygon(myGraphic1.geometry).extent); } MainMap.extent = unionExtent; } } function onFault(info:Object, token:Object = null):void { Alert.show(info.toString()); } } private function sfDataGrid_Click():void { var obj:Object = sfDataGrid.selectedItem; if (obj != null) { lastIdentifyResultGraphic = null; query.where = "STATE_NAME = '" + obj["STATE_NAME"] + "'" queryTaskZoom.execute(query, new AsyncResponder(onResult, onFault)); function onResult(featureSet:FeatureSet, token:Object = null):void { lastIdentifyResultGraphic = featureSet.features[0]; lastIdentifyResultGraphic.symbol = sfs; MainMap.extent = new Extent(lastIdentifyResultGraphic.geometry.extent.xmin,lastIdentifyResultGraphic.geometry.extent.ymin,lastIdentifyResultGraphic.geometry.extent.xmax,lastIdentifyResultGraphic.geometry.extent.ymax); } function onFault(info:Object, token:Object = null):void { Alert.show(info.toString(), "Query Problem"); } } } ]]> </mx:Script> <!-- Start Declarations --> <!-- Symbol for Query Result as Polygon --> <esri:SimpleFillSymbol id="sfs" alpha="0.7" color="0xFF0000"/> <!-- Layer with US States --> <esri:QueryTask id="queryTask" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"/> <esri:QueryTask id="queryTaskZoom" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"/> <esri:Query id="query" text="{fText.text}" returnGeometry="true" outSpatialReference="{MainMap.spatialReference}"> <esri:outFields> <mx:String>MED_AGE</mx:String> <mx:String>POP2007</mx:String> </esri:outFields> </esri:Query> <!-- End Declarations --> <mx:HBox width="100%" height="40" backgroundColor="0xDDDDFF" paddingTop="10" horizontalAlign="center"> <mx:Text text="Search for U.S. States:"/> <mx:TextInput id="fText" enter="doQuery()" text="Ca"/> <mx:Button label="Query" click="doQuery()"/> </mx:HBox> <mx:Text id="resultSummary" height="15"/> <mx:VDividedBox height="100%" width="100%"> <esri:Map id="MainMap"> <esri:extent> <esri:Extent xmin="-126" ymin="24" xmax="-67" ymax="50"> <esri:SpatialReference wkid="4326"/> </esri:Extent> </esri:extent> <esri:ArcGISDynamicMapServiceLayer url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StateCityHighway_USA/MapServer"/> <esri:GraphicsLayer id="myGraphicsLayer" symbol="{sfs}" graphicProvider="{lastIdentifyResultGraphic}"/> </esri:Map> <mx:DataGrid id="sfDataGrid" click="sfDataGrid_Click()" dataProvider="{queryTask.executeLastResult.attributes}" scroll="true" width="100%" height="40%"/> </mx:VDividedBox> </mx:Application>
private function selectRow(event:ListEvent):void { var selectedGraphic:Graphic; var attr:Object = event.itemRenderer.data; var i:int=0; for each (var graphic:Graphic in graphicsLayer.graphicProvider) { graphic.symbol=symbol1; i++; if (graphic.attributes == attr){ selectedGraphic=graphic; selectedGraphic.symbol=selSymbol; graphicsLayer.moveToTop(selectedGraphic); zoomToRow(selectedGraphic); } } } private function zoomToRow(graphic:Graphic):void { var offset:int=3000; var graphicsExtent:Extent; if (graphic){ graphicsExtent = graphic.geometry.extent; graphicsExtent.xmax=graphicsExtent.xmax+offset; graphicsExtent.xmin=graphicsExtent.xmin-offset; graphicsExtent.ymax=graphicsExtent.ymax+offset; graphicsExtent.ymin=graphicsExtent.ymin-offset; map1.extent = graphicsExtent; // make sure the whole extent is visible if (!map1.extent.containsExtent(graphicsExtent)){ map1.level--; } } }
<esri:SimpleFillSymbol id="symbol1" style="solid" color="0xFF0000" alpha="0.3"> <esri:outline> <esri:SimpleLineSymbol style="solid" color="0x000000" width="2" /> </esri:outline> </esri:SimpleFillSymbol> <esri:SimpleFillSymbol id="selSymbol" style="solid" color="0x22BB99" alpha="1"> </esri:SimpleFillSymbol>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Query, then zoom to results"> <fx:Script> <![CDATA[ import com.esri.ags.FeatureSet; import com.esri.ags.Graphic; import com.esri.ags.geometry.Extent; import com.esri.ags.geometry.Polygon; import mx.controls.Alert; import mx.rpc.AsyncResponder; [Bindable] private var lastIdentifyResultGraphic:Graphic; private function doQuery():void { query.text = fText.text; query.where = "*"; queryTask.execute(query, new AsyncResponder(onResult, onFault)); function onResult(featureSet:FeatureSet, token:Object = null):void { // clear the graphics layer myGraphicsLayer.clear(); if (featureSet.features.length == 0) { Alert.show("No States found. Please try again."); } else { var unionExtent:Extent; var myFirstGraphic:Graphic = featureSet.features[0]; unionExtent = Polygon(myFirstGraphic.geometry).extent; for each (var myGraphic1:Graphic in featureSet.features) { myGraphicsLayer.add(myGraphic1); unionExtent = unionExtent.union(Polygon(myGraphic1.geometry).extent); } MainMap.extent = unionExtent; } } function onFault(info:Object, token:Object = null):void { Alert.show("-->Error Here<--" + info.toString()); } } private function sfDataGrid_Click():void { var obj:Object = sfDataGrid.selectedItem; if (obj != null) { lastIdentifyResultGraphic = null; query.where = "CO_NAME = '" + obj["CO_NAME"] + "'"; queryTaskZoom.execute(query, new AsyncResponder(onResult, onFault)); function onResult(featureSet:FeatureSet, token:Object = null):void { lastIdentifyResultGraphic = featureSet.features[0]; lastIdentifyResultGraphic.symbol = sfs; MainMap.extent = new Extent(lastIdentifyResultGraphic.geometry.extent.xmin, lastIdentifyResultGraphic.geometry.extent.ymin, lastIdentifyResultGraphic.geometry.extent.xmax,lastIdentifyResultGraphic.geometry.extent.ymax); } function onFault(info:Object, token:Object = null):void { Alert.show("Query Problem ", info.toString()); } } } ]]> </fx:Script> <fx:Declarations> <!-- Symbol for Query Result as Polygon --> <esri:SimpleFillSymbol id="sfs" alpha="0.7" color="0xFF0000"/> <!-- Layer with US States --> <esri:QueryTask id="queryTask" showBusyCursor="true" url="http://geonexus/ArcGIS/rest/services/Boundaries/COUNTY_BORDERS_SO/MapServer/0"/> <esri:QueryTask id="queryTaskZoom" showBusyCursor="true" url="http://geonexus/ArcGIS/rest/services/Boundaries/COUNTY_BORDERS_SO/MapServer/0"/> <esri:Query id="query" text="{fText.text}" returnGeometry="true" outSpatialReference="{MainMap.spatialReference}"> <esri:outFields> <fx:String>CO_NUMBER</fx:String> <fx:String>COUNTY_YEAR</fx:String> </esri:outFields> </esri:Query> </fx:Declarations> <mx:VDividedBox height="100%" width="100%"> <mx:HBox width="100%" height="40" backgroundColor="0xDDDDFF" paddingTop="10" horizontalAlign="center"> <mx:Text text="Search for U.S. States:"/> <mx:TextInput id="fText" enter="doQuery();" text="Lyon"/> <mx:Button label="Query" click="doQuery();" enabled="true"/> </mx:HBox> <mx:Text id="resultSummary" height="15"/> <!--The map--> <esri:Map id="MainMap" openHandCursorVisible="false" level="7" logoVisible="false" extent="{new Extent(-10884964.57, 4660003.62, -9907264.87, 5649404.52, new SpatialReference(102113))}"> <esri:ArcGISTiledMapServiceLayer url="http://geonexus/ArcGIS/rest/services/Basemap/Basemap/MapServer"/> <esri:GraphicsLayer id="myGraphicsLayer" symbol="{sfs}" graphicProvider="{lastIdentifyResultGraphic}"/> </esri:Map> <mx:DataGrid id="sfDataGrid" click="sfDataGrid_Click()" dataProvider="{queryTask.executeLastResult.attributes}" scroll="true" width="100%" height="40%"/> </mx:VDividedBox> </s:Application>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" minWidth="1024" minHeight="768" xmlns:esri="http://www.esri.com/2008/ags" xmlns:mx="library://ns.adobe.com/flex/mx" > <fx:Declarations> <!--Queried layer--> <esri:QueryTask id="queryTask" url="http://mapserver.ujep.cz/ArcGIS/rest/services/Projekty/Lomy/MapServer/0"/> <!--Querry the type of rock (Hornina)--> <esri:Query id="query" where="Hornina='{typesChoose.selectedItem}'" returnGeometry="true" outSpatialReference="{mainMap.spatialReference}"> <esri:outFields> <fx:String>Umisteni</fx:String> <fx:String>Majitel</fx:String> <fx:String>Kontakt</fx:String> <fx:String>Zrnitost</fx:String> <fx:String>Hornina</fx:String> </esri:outFields> </esri:Query> </fx:Declarations> <esri:Map id="mainMap"> <esri:extent> <esri:Extent xmax="-885425.789" ymax="-954466.567" xmin="-702106.51" ymin="-1044718.028"> <esri:SpatialReference wkid="102067"/> </esri:Extent> </esri:extent> <esri:ArcGISTiledMapServiceLayer url="http://mapserver.ujep.cz/ArcGIS/rest/services/NAKI/Data200_cached/MapServer"/> <esri:GraphicsLayer id="myGraphicsLayer" graphicProvider="{queryTask.executeLastResult.features}"> <esri:renderer> <esri:SimpleRenderer> <esri:SimpleMarkerSymbol id="basicSmybol" color="red" style="diamond"/> </esri:SimpleRenderer> </esri:renderer> </esri:GraphicsLayer> </esri:Map> <s:Panel top="50" right="50" id="leftPanel" width="350" height="400"> <s:layout> <s:VerticalLayout horizontalAlign="left" paddingLeft="10" paddingRight="10" paddingTop="10" paddingBottom="10" /> </s:layout> <!--Choose the rock type--> <s:ComboBox id="typesChoose" selectedItem=" " width="75%" change="queryTask.execute(query)"> <s:ArrayCollection> <fx:String>B�?idlice</fx:String> <fx:String>�?edič</fx:String> <fx:String>Rula</fx:String> <fx:String>Vápenec</fx:String> <fx:String>Žula</fx:String> </s:ArrayCollection> </s:ComboBox> <mx:DataGrid id="resultsGrid" width="100%" height="100%" dataProvider="{queryTask.executeLastResult.attributes}"> <mx:columns> <mx:DataGridColumn headerText="Umíst�?ní" dataField="Umisteni" /> <mx:DataGridColumn headerText="Majitel" dataField="Majitel" width="130"/> <mx:DataGridColumn headerText="Kontakt" dataField="Kontakt"/> </mx:columns> </mx:DataGrid> </s:Panel> </s:Application>
