Not necessarily. The add will only work if the spatial extent is set and there are values for the NoData areas. If there are not any values there, the Add will only return the intersection of the two rasters. You would have to make the spatial extents match and then change the nodata values to 0 rather than null and then when you add them, the raster would look appropriate. I would recommend using the Mosaic to New Raster Tool in Data Management > Raster > Raster Dataset to complete the process since the 'merge' functionality is no longer available in Raster Calculator. http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001700000098000000.htm
This is absolutely ridiculous, taking away the flexibility and usability of raster calculator combined with the old arcInfo functions was one of the worst design flaws of Arc10...
. I also miss having functionality right in the Spatial Analyst toolbar when working within ArcMap. Now I have to go into the toolbox just to use the raster calculator.
I suppose I will have to use the Mosaic mentioned above instead
it works for me. Thanks
Yeah, very simple and useful tool, I can't believe I didn't know it 😄 Thanks a lot!
