I exported to a DXF and it showed perfect when I brought it into Arc. Remember to set your projection.
We are experiencing the same issue here. We using ArcGIS 10.2 . Most of dgn's that are causing problems are ones that are imported from other users/department. We need a fix to this ASAP! ESRI keeps saying this is caused by a corrupted world file. Is the issue still present in 10.2.1?
Because I have both Microstation and ArcGIS, I was able to find the coordinate location (start x,y and end x,y) of a 2 point line that crosses my general spatial work area.I found the x,y coords in ArcGIS and I found the same x,y coords in Microstation and then came up with a "world" file."esri_cad.wld"-1853483.648,-1789483.648 290000.000,5654000.000-1447483.648,-1456483.648 696000.000,5987000.000This world file works for me (UTM Zone 10, NAD83) but I doubt it would work for most other folks.This issue has been identified as a "bug" (by ESRI) in ArcGIS 10.2Chris
