Hi! I using WGS84 coordinate system in my project. If I will export web scene, arcscene give this error;
ArcGIS needs to use a spatial reference with a projected coordinate system to display features in the proper location.
Specify a spatial reference with a projected coordinate system.
Thanks, I'm publish utm but my layers seen to small. Why?
Just following this
Defining or modifying a raster's coordinate system—Help | ArcGIS for Desktop
but your raster may be different. That information might be useful. And a GCS_WGS 84 is not a projected coordinate system, so if it is defined correctly, then use the Project tool to project it to something projected (ie UTM etc etc)P
I'm already use Data Management Tools >> Projections and Transformations >> Define Projection. I'm set GCS_WGS_1984 but don't working
whatever the file is, it needs a coordinate system whether it is an image or shapefile. You need to use the Data Management, Define Projection tool
