Hi,I'm unable to use Python/Geoprocessing to read data from an ESRI Query Layer. How can I make this work?I've tried two things:1) Use Make Feature Layer to read from .lyrReference: http://forums.arcgis.com/threads/584-beta-10-system-tool-for-extracting-query-layer-data-to-file-gdbCode explained: Works for .lyr based on layer (data source is sde spatial view which arcgis sees as a feature class). Does not work for .lyr based on query layer (data source is sde view which arcgis sees as a table).# Import system modules
import sys, string, os, arcpy
arcpy.AddMessage("start script....")
#lyr = "C:\Projects\BranchMapping\dev\src\GP_Tasks\ppOwner.lyr"
lyr = "C:\Projects\BranchMapping\dev\src\GP_Tasks\BRANCHES.lyr"
#qry = "KeyInstn = 4001616" # D
qry = "KeyInstn = 4019974" # VABK
arcpy.AddMessage("Making feature layer....")
arcpy.MakeFeatureLayer_management(lyr, "lyr", qry)
arcpy.AddMessage("Getting count....")
result = arcpy.GetCount_management("lyr")
count = int(result.getOutput(0))
arcpy.AddMessage(str(count))2) MakeQueryTable Reference: http://forums.arcgis.com/threads/25496-Query-Layer?highlight=query+layer+geoprocessing+pythonOpening the tool I browse to the sde view. Afterwards I get this error: ERROR 000793Invalid data element type ERROR 000840: The value is not a Raster Layer.I read the doc, but I don't understand. Can I use this tool to create a layer from a "query layer" table data source (i.e. same data source that I can use to create a Query Layer in ArcMap).Does ESRI have a way to use PY to read data from a Query Layer data source?Thanks,-Cory
