Is it possible to use the Attribute Assistant tool in the Collector for GIS or Web Maps to automatically populate fields in new dropped points?
This is an excellent question, has anyone answered this yet? We could use this is in our setup at work
Attribute Assistant is not configured to work with ArcGIS for Server feature services, and therefore edits applied from the web are not "listened" by Attribute Assistant.
There is an ArcGIS Idea to implement the functionality in a web environment:
http://ideas.arcgis.com/ideaView?id=087E000000059fTIAQ
Also, others have configured the GeoEvent Processor to have similar functionality as the Attribute Assistant. There are methods for performing a variety of field calculations using the GeoEvent Processor, and therefore can be configured to do many of the Attribute Assistant methods.
As an alternative approach, you can implement a few features and workflow adjustments to use Attribute Assistant and Attribute Assistant-like methods against web edits.
Ultimately, workarounds exist, but like many others, this functionality is desired in the web environment. With GeoEvent processor available however, I doubt there are any internal pushes from Esri to implement a web version of Attribute Assistant any time soon.
Good Luck!
Thank you for this information.
Jeff Jackson
City of Memphis Information Services
Enterprise GIS Group
119 S Main St, Suite 200
Memphis, TN 38103
Office: 901-636-7151
Hello Chris,
Thanks for the response!
I've been scouring the web looking for any tips on how to automate Attribute Assistant..... I was hoping you could elaborate a little bit or direct me to some sources on how this is done. You mentioned this in:
3. (Nightly Python Scripts to update data
I've got AA configured and the rules are running fine. I'd like to create a script to run the "Manual" Rules nightly. How do you go about calling Attribute Assistant from python?
Thanks!
Has this been done yet? Is the Attribute Assistant available on AGOL or WAB for Developers yet?
We need to prepopulate fields based on spatial location.
Hi Marcus,
Using python scripts to call Attribute Assistant is not the method I am describing. My apologies for being vague. What I meant was you could write your own python script to replicate many of the methods that exist attribute assistant, through geoprocessing functions and other spatial modules.
Chris
Hi Brian,
No, and I would not expect it to ever be done through Attribute Assistant, AGOL, etc.
You may want to look into spinning up your own script to handle your field calculations.
Here is a current link to the Idea for adding Attribute Assistant:
https://community.esri.com/ideas/8713
