Here was the test scenario:1. Register SDE feature class as versioned2. Create attachments for the feature class3. Add Global IDs to the feature class4. Create the replica5. Add an attachment to a feature6. SynchronizeI found that if the attachments are created before you add the Global IDs that when you add the Global IDs to the feature class, the related attachment table will receive a Global ID field as well. If the Global IDs are added before the attachments are created, the related attachment table will need to have Global IDs manually added to it.Check to make sure your feature class and attachments table both have the Global ID field.
Hi Brad,I could not find any documentation, but after a quick test, this appears to be supported. I was able to replicate an SDE feature class with attachments to another SDE geodatabase. I am running:ArcGIS 10 SP3ArcSDE 10 SP3SQL Server 2008 SP1Are you receiving any error messages?
