I can not reproduce resizing the window and having the export name and options all disappear. Try putting the focus in the export window and typing shift + O (hotkey combination for the options dropdown).ALso, the lower right corner with the triangle of dots does nothing?Other options:1) spend some time with tech support2) get into the registry and try to reset that specific window settings (always a dangerous thing)3) rename or delete the Normal.mxt - This will reset all windows, toolbars, and customizations to original install settings.Regards, and good luck!Jim
Did you change the resolution for your monitor or for your map to print. Changing the export or print resolution should not do as you indicate.
I was changing the resolution of a map to export (in the export map window) and downsized the bottom half of the window to view part of the map, but a similar arrow resize the window does not appear. Now I am unable to rename a file or change the resolution for export. I created an entirely new .mxd and have the same problem. I have version 10.0 desktop. Has anyone run into this problem?
