I am trying to compile the Flex Viewer 2.0 "HelloWorldWidget" using MXMLC in the SDK. I am getting the following error messages:\com\esri\viewer\IBaseWidget.as(94): col: 28 Error: Type was not found or was not a compile-time constant: Map. function set map(value:Map):void;\com\esri\viewer\IBaseWidget.as(95): col: 24 Error: Type was not found or was not a compile-time constant: Map. function get map():Map;I managed to compile and deploy few Flex API 2.0 sample applications but can�??t port these applications to widgets.Your help is highly appreciated!Jonathan Feng
