We have an app that was created with webappbuilder 2.2 that only hold one layer.
This layer has 14 polygones and we want to send papramter to the map so it will open with the realvant polygone
instead of creating 14 diffrent apps / maps.
For example -
http://gisserver/portal/apps/webappviewer/index.html?id=92fa9ecbb5cc433daa7ce8c9fe18cf45&FILTER=MYLAYER, Code=1-14 ( 1,2,3...14 )
The same as here Use URL parameters to modify maps—ArcGIS Online Help | ArcGIS but filter the data.
Hope i make myself clear..
Avishai
I marked you other post as a dupe so this should be you primary.
tagging https://community.esri.com/community/gis/web-gis/web-appbuilder?sr=search&searchId=e94524a8-dd10-4acf-a3b3-59b6eb3a6f94&searchIndex=5 and https://community.esri.com/community/gis/web-gis?sr=search&searchId=35182f98-1037-42cf-9e05-27330fb260a4&searchIndex=3 for more exposure.
Avishai,
So you are saying that you are having a hard time figuring out how to use the Query or find parameters?
Use URL parameters—Web AppBuilder for ArcGIS | ArcGIS
The "Query a feature" only zooms in and select the feature and does not filter the data ( removes all other features )
You can se from the help Doc I linked to there is no filter parameter. Only query and find.
Right - my question is if if it possible to do? and how ?
