Does anyone have any experience installing and configuring Utility Network Management Extension? Is it installed on a separate installer file? Or is it installed on with the ArcGIS Server installer?
Bill
Hi Bill,
If you have ArcGIS Server installed and configured, you just need to license the Utility Network Management Extension with the server site.
Best,
Tom
Thanks!
Hi, I've installed and authorised both ArcGIS server and the Utility Network Management extension but the UNME does not show up under GIS Server > Extensions. Is this normal?
Cheers,
Rich
Richard,
Yes this appears to be correct as UN is not an extension but a licensed server role. I have the same here with our current PoC solution.
Damien
Hi Rich,
From Server Manager, go to Site > Software Authorization and here you should see the roles and extensions that ArcGIS Server is licensed for.
GIS Server > Extensions is where you will find server object extensions (SOEs) and server object interceptors (SOIs). SOEs allow you to create new service operations and SOIs allow you to intercept requests for existing built-in service operations.
Best Regards,
