<?xml version="1.0" ?> <!-- //////////////////////////////////////////////////////////////////////////////// // // Copyright (c) 2010 ESRI // // All rights reserved under the copyright laws of the United States. // You may freely redistribute and use this software, with or // without modification, provided you include the original copyright // and use restrictions. See use restrictions in the file: // <install location>/License.txt // //////////////////////////////////////////////////////////////////////////////// --> <configuration> <httpproxy enabled="false">proxy.php</httpproxy> <title>Bartow County</title> <subtitle>Floodplain Mapping Application</subtitle> <logo>assets/images/bartow_courthouse.png</logo> <stylesheet>blackgold.swf</stylesheet> <!-- UI elements --> <widget left="0" top="0" config="widgets/HeaderController/HeaderController.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/> <widget right="1" bottom="1" config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/> <map initialextent="1989177 1488269 2190132 1605493"> <basemaps> <mapservice label="Basemap" type="tiled" visible="true" alpha="1" url="http://publicgis/PublicGISserver/rest/services/Basemap/MapServer"/> </basemaps> <operationallayers> <layer label="2008 Aerial Photo" type="dynamic" visible="false" url="http://publicgis/PublicGISserver/rest/services/2008_Aerial_Photo/MapServer"/> <layer label="Basemap" type="tiled" visible="false" url="http://publicgis/PublicGISserver/rest/services/Basemap/MapServer"/> <layer label="2007 Cross Sections" type="tiled" visible="false" url="http://publicgis/PublicGISserver/rest/services/2007_CrossSections/MapServer"/> <layer label="2007 Bartow Floodplain" type="tiled" visible="false" visiblelayers="" url="http://publicgis/PublicGISserver/rest/services/2007_BartowFloodplain/MapServer"/> <layer label="2010 Cross Sections" type="tiled" visible="false" url="http://publicgis/PublicGISserver/rest/services/2010_CrossSections/MapServer"/> <layer label="2010 Bartow Floodplain" type="tiled" visible="false" alpha="0.5" visiblelayers="" url="http://publicgis/PublicGISserver/rest/services/2010_BartowFloodplain/MapServer"/> </operationallayers> </map> <!-- widgets organized into widget containers that manage close/open etc --> <!-- supported layout property options: horizontal(default)|float|vertical|fix--> <widgetcontainer layout="float"> <widget label="Navigation Tools" x="975" y="50" icon="assets/images/i_nav.png" config="widgets/NavigationTools/NavigationToolsWidget.xml" url="widgets/NavigationTools/NavigationToolsWidget.swf"/> <widget label="Dynamic Legend" x="25" y="565" icon="assets/images/i_legend2.png" config="widgets/DynamicLegend/DynamicLegendWidget.xml" url="widgets/DynamicLegend/DynamicLegendWidget.swf"/> <widget label="Layer List" x="975" y="280" icon="assets/images/i_layers.png" config="widgets/LayerList/LayerListWidget.xml" url="widgets/LayerList/LayerListWidget.swf"/> <widget label="Search" x="25" y="320" icon="assets/images/i_search.png" config="widgets/Search/SearchWidget_Bartow.xml" url="widgets/Search/SearchWidget.swf"/> <widget label="Print" x="975" y="585" icon="assets/images/i_print.png" config="widgets/Print/PrintWidget.xml" url="widgets/Print/PrintWidget.swf"/> </widgetcontainer> </configuration>
