Dim pSpaRefDlg As ISpatialReferenceDialog Set pSpaRefDlg = New SpatialReferenceDialog Dim m_pSpaRef1 As ISpatialReference Set m_pSpaRef1 = pSpaRefDlg.DoModalCreate(False, False, False, Form1.ActiveControl) 'Use M and Z
Dim pSpatialref As IProjectedCoordinateSystem Dim pSpaRefDlg As ISpatialReferenceDialog Set pSpaRefDlg = New SpatialReferenceDialog Set pSpatialref = pSpaRefDlg.DoModalCreate(False, False, False, Form1.ActiveControl) 'Use M and Z
Hello Melita,Thanks a lot for your reply. Thanks to it, I find out in the documentation the following code that allows to set the "'Geographic Coordinate System" directly within ArcGIS (and not from ArcCatalog as you have proposed).Now, my problem is to find out how to set also the "Projected Coordinate System" (for example: esriSRProjCS_CH1903_LV03)If anyone has an idea? Thank you in advance for your helpKind regardsCharles.
Sub Layer_GeographicCoordSyst() Dim pMxDoc As IMxDocument, pMap As IMap Set pMxDoc = ThisDocument Set pMap = pMxDoc.FocusMap Dim pLayer As IFeatureLayer, pFeatureClass As IFeatureClass Dim pGeoDataset As IGeoDataset, pGeoDatasetEdit As IGeoDatasetSchemaEdit Set pLayer = pMap.Layer(0) Set pFeatureClass = pLayer.FeatureClass Set pGeoDataset = pFeatureClass Set pGeoDatasetEdit = pGeoDataset If pGeoDatasetEdit.CanAlterSpatialReference = True Then Dim pSpatRefFact As ISpatialReferenceFactory2 Set pSpatRefFact = New SpatialReferenceEnvironment Dim pProjCoordSys As IProjectedCoordinateSystem Set pProjCoordSys = pSpatRefFact.CreateProjectedCoordinateSystem(esriSRProjCS_CH1903_LV03) ' Debug.Print pLayer.Name, pProjCoordSys.Name pGeoDatasetEdit.AlterSpatialReference pProjCoordSys End If pMxDoc.ActiveView.PartialRefresh esriViewGeography, pLayer, Nothing End Sub
Sub Layer_GeographicCoordSyst() Dim pMxDoc As IMxDocument, pMap As IMap Set pMxDoc = ThisDocument Set pMap = pMxDoc.FocusMap Dim pLayer As IFeatureLayer, pFeatureClass As IFeatureClass Dim pGeoDataset As IGeoDataset, pGeoDatasetEdit As IGeoDatasetSchemaEdit Set pLayer = pMap.Layer(0) Set pFeatureClass = pLayer.FeatureClass Set pGeoDataset = pFeatureClass Set pGeoDatasetEdit = pGeoDataset If pGeoDatasetEdit.CanAlterSpatialReference = True Then Dim pSpatRefFact As ISpatialReferenceFactory2 Set pSpatRefFact = New SpatialReferenceEnvironment Dim pGeoCoordSys As IGeographicCoordinateSystem Set pGeoCoordSys = pSpatRefFact.CreateGeographicCoordinateSystem(esriSRGeoCS_CH1903) ' Debug.Print pLayer.Name, pGeoCoordSys.Name pGeoDatasetEdit.AlterSpatialReference pGeoCoordSys End If pMxDoc.ActiveView.PartialRefresh esriViewGeography, pLayer, Nothing End Sub
Hello,Here is my question: I would like to set the Coordinate system using a sub VBA - (ArcObjects) (Please not with ArcToolBox !) when the Coordinate System of the Layer is "undefined"Of course, the Coordinate System is imposed according to my choice.Thank you for your help...Kind regards,Charles.
' changes spatialref of data in arcmap. coverages not working; see kirk's code ' below this sub. public sub redefinedatasets() 'On Error GoTo errorhandler: Dim pMxDoc As IMxDocument Dim pDataLayer As IDataLayer2 Dim pName As IName Dim pGxObjectInternalName As IGxObjectInternalName Dim pGxObject As IGxObject Dim pmap As IMap Set pMxDoc = pApp.Document Set pmap = pMxDoc.FocusMap Set pDataLayer = pMxDoc.SelectedLayer If pDataLayer Is Nothing Then MsgBox "Please Select a Layer First", vbExclamation, "Select A layer first" Exit Sub End If Set pName = pDataLayer.DataSourceName Set pGxObjectInternalName = New GxDataset Set pGxObjectInternalName.InternalObjectName = pName Set pGxObject = pGxObjectInternalName 'I also have another problem where the dataset goes outside the spatial envelope 'any suggestions on how to expand the envelope to account for the new projection 'would be appreciated. Dim pSpatRefDialog As ISpatialReferenceDialog Dim pSpatRef As ISpatialReference Dim pRasterDataset As IRasterDataset Dim pDataset As IDataset Dim pGeoDatasetSchemaEdit As IGeoDatasetSchemaEdit Dim pGXdataset As IGxDataset 'call the spatial reference dialog Set pSpatRefDialog = New SpatialReferenceDialog Set pSpatRef = pSpatRefDialog.DoModalCreate(False, False, False, 0) Set pGXdataset = pGxObject If pGXdataset.Type = esriDTRasterDataset Then Set pRasterDataset = pGXdataset.Dataset Set pGeoDatasetSchemaEdit = pRasterDataset 'this is for featureclasses ElseIf pGXdataset.Type <> esriDTRasterDataset Then Set pDataset = pGXdataset.Dataset 'COVERAGE DIES RIGHT HERE!!! 'ERROR TYPE MISMATCH 'WORKS FINE FOR SHPS AND GDBS Set pGeoDatasetSchemaEdit = pDataset End If 'this prevents the cancel error If pSpatRef Is Nothing Then Exit Sub End If If pGeoDatasetSchemaEdit.CanAlterSpatialReference = True Then pGeoDatasetSchemaEdit.AlterSpatialReference pSpatRef Else MsgBox "Cannot Edit the Spatial Reference." & _ "Perhaps you have a lock somewhere else on the dataset", vbExclamation, "Probably Locked" End If 'zoom to layer Dim pactiveview As IActiveView Set pactiveview = pmap Dim player As ILayer Set player = pMxDoc.SelectedLayer pactiveview.Extent = player.AreaOfInterest pactiveview.Refresh 'cleanup Set pMxDoc = Nothing Set pDataLayer = Nothing Set pName = Nothing Set pGxObjectInternalName = Nothing Set pGxObject = Nothing Set player = Nothing Set pactiveview = Nothing Exit Sub 'errorhandler: msgbox err.description exit sub end sub Option Explicit Sub SetPrj() Dim pSRF As ISpatialReferenceFactory2 Set pSRF = New SpatialReferenceEnvironment Dim pSR As ISpatialReference Set pSR = pSRF.CreateProjectedCoordinateSystem(esriSRProjCS_WGS1972UTM_30S) Dim pGxApp As IGxApplication Set pGxApp = Application If TypeOf pGxApp.SelectedObject Is IGxDataset Then Dim pGxDataset As IGxDataset Set pGxDataset = pGxApp.SelectedObject If TypeOf pGxDataset.DatasetName Is ICoverageName Then Dim pGDSE As IGeoDatasetSchemaEdit Set pGDSE = pGxDataset.Dataset If pGDSE.CanAlterSpatialReference Then pGDSE.AlterSpatialReference pSR Else Debug.Print "cannot alter spatial reference of coverage" End If End If End If End Sub
