Matt,in your MXD just right-click your layer in the Table of content, Data -> export Data. This will save it as a shapefile.Tim
In what format is the data that you are trying to export (The data that gives the error message)?
Okay so it looks like you're trying to export the ArcMap Document file (.mxd). This is the workspace you are working on and not the files you are trying to export. Open the .mxd file and look in the Table of Contents at the left hand side of the screen (If it's not there click the Window drop down menu at the top of the screen then select Table of Contents). What you want to do is right click on the layers in the Table of Contents then go to Data and then Export Data.It will also help if you know your files are vector or raster data.
Thanks, and as I mentioned before Im new to arcGIS so its a little tricky for me...what is the difference between vector and raster data?
Also, Is it possible to export a layer as a kmz. file which seems to be much easier to work with in google pro rather than a shape file?
