When I click om my Map View, it takes time to appear my custom popup. How can I show "Wait cursor" like default popups during this time?
The cursor is set from CSS. So setting the view container's style.cursor attribute to "wait" will do this. ie:
<SPAN class="keyword token">var</SPAN> el<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// the element containing your map (3.X) or view (4.X)</SPAN> el<SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>cursor <SPAN class="operator token">=</SPAN> <SPAN class="string token">"wait"</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
In the 4.X API, you should be able to get a reference to the surface element using view.surface. From here, you can set the "data-cursor" attribute to change the cursor:
view<SPAN class="punctuation token">.</SPAN>surface<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setAttribute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"data-cursor"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"wait"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// set to wait</SPAN> view<SPAN class="punctuation token">.</SPAN>surface<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setAttribute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"data-cursor"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"default"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// back to default</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
In js api 4.11 (4.12) you can use undocumented "Spinner widget ".
It does the job when you use default popup widget, but it could be shown by your code too:
require([ // "esri/widgets/Spinner", //... ], function( //... Spinner, ) { //... const spinner = new Spinner({ view: view }); view.ui.add(spinner); //... view.on("click", runIdentify); //... function runIdentify(event) { spinner.show({ location : event.mapPoint }); } //... spinner.hide(); }<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
