Hi,I have code running in 10.0:Dim pGxObject As ESRI.ArcGIS.Catalog.IGxObjectpGxCatalog = New ESRI.ArcGIS.Catalog.GxCatalogClassThis gives me an error message upon upgrading to 10.1, it appears GxCatalogClass no longer exists. Anyway to make my code work in 10.1? I'm trying to gain access to the GetObjectFromFullName method.Thanks,Pete
I realize this is an old post, but I was having the same problem with setting an IGxCatalog variable to a new GxCatalogClass, and the other suggestions did not help (someone on StackExchange (arcgis 10.0 - Cant cast to IGxCatalog - Geographic Information Systems Stack Exchange) suggested using the Activator class, also.)
You did not mention if you were running this inside an Esri program like ArcMap or ArcCatalog, but for us, running inside ArcMap, I found that at 10.1+ ArcMap implements the IGxApplication interface, which has a Catalog property, and using that method worked. For us.
The properties of IGxApplication and the classes that implement it are available here:
ArcObjects Help for .NET developers
