dojo/parser::parse() error Error: ReferenceError: bottom is not defined in data-dojo-props='region: bottom'
<div id="outGrid" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region: bottom">
<div id="outGrid" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region: 'bottom'">
<title> Text Search </title> <script src="http://js.arcgis.com/3.6/"> </script> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dojox/grid/resources/Grid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dojox/grid/resources/tundraGrid.css"> <style> html, body, #grid { height: 100%; margin: 0; overflow: hidden; padding: 0; width:100% } </style> <script> require([ "dojo/_base/declare", "dojo/store/Memory", "dgrid/OnDemandGrid", "dojo/parser", "dojo/ready", "esri/tasks/query", "esri/tasks/QueryTask", "dojo/dom", "dojo/on", "dojo/_base/array" ], function(declare, Memory, OnDemandGrid, parser, ready, Query, QueryTask, dom, on, array) { var myQuery, myQueryTask; var StandardGrid = declare([OnDemandGrid]); var grid = new StandardGrid({ bufferRows: 50, columns: { apino: "API No", otherid: "State Permit No", wellname: "Operator", county: "County", twp: "Township", rge: "Range", section_: "Section", drillertotaldepth: "Depth (ft)", formationtd: "Formation at Depth", folderField: "Well Folder", logField: "Scanned Well Log", lasField: "LAS Data" } }, "grid"); ready(function() { // Make sure all elements are loaded and accessible parser.parse(); // Run the Query runQuery(); function runQuery() { myQuery = new Query(); myQueryTask = new QueryTask("http://services.azgs.az.gov/ArcGIS/rest/services/aasggeothermal/AZWellHeaders/MapServer/0"); myQuery.returnGeometry = false; myQuery.outFields = ["apino", "otherid", "wellname", "county", "twp", "rge", "section_", "drillertotaldepth", "formationtd", "field", "relatedresource", "welltype"]; myQuery.where = "apino like '%%'" + " OR " + "otherid like '%%'"; myQueryTask.execute(myQuery, updateGrid); } function showResults(myFeatures) { console.log(myFeatures); var s = ""; for (var i = 0, il = myFeatures.features.length; i < il; i++) { var featureAttributes = myFeatures.features.attributes; for (att in featureAttributes) { s = s + "<strong>" + att + ": </strong>" + featureAttributes[att] + "<br />"; } } dojo.byId("info").innerHTML = s; } function updateGrid(featureSet) { console.log("featureSet", featureSet); var data = []; array.forEach(featureSet.features, function(entry) { var logs = [], las = [], folders = [], relatedResource = entry.attributes.relatedresource === null ? "no value" : entry.attributes.relatedresource; var raw = relatedResource.split("|"); raw.forEach(function(bit) { var resource = bit.split(", "); if (resource[0] && resource[1]) { var url = resource[1].trim(); var name = resource[0].trim(); } var anchor = "<li><a href='" + url + "' target='_blank'>" + name + "</a></li>"; if (url != null) { if (url.indexOf(".tif", url.length - 4) !== -1) { logs.push(anchor); } if (url.indexOf(".pdf", url.length - 4) !== -1) { folders.push(anchor); } if (url.indexOf(".las", url.length - 4) !== -1) { las.push(anchor); } } }); data.push({ objectid: entry.attributes.objectid, apino: entry.attributes.apino, otherid: entry.attributes.otherid, wellname: entry.attributes.wellname, county: entry.attributes.county, twp: entry.attributes.twp, rge: entry.attributes.rge, section_: entry.attributes.section_, drillertotaldepth: entry.attributes.drillertotaldepth, formationtd: entry.attributes.formationtd, logField: '<ul>' + logs.join(" ") + '</ul>', lasField: '<ul>' + las.join(" ") + '</ul>', folderField: '<ul>' + folders.join(" ") + '</ul>' }); }); var dataForGrid = { items: data }; //console.log(data); var store = new Memory({ data: dataForGrid, idProperty: "apiNo" }); grid.setStore(store); } }); }); </script> </head> <body class="tundra"> <div id="grid" style="margin:0; padding:0;"></div> </body> </html>
