var extent : Extent = Graphic(event.target).geometry as Extent; const arrPoints:Array = [ new MapPoint(extent.xmin, extent.ymin), new MapPoint(extent.xmin, extent.ymax), new MapPoint(extent.xmax, extent.ymax), new MapPoint(extent.xmax, extent.ymin), new MapPoint(extent.xmin, extent.ymin) ]; var polygon:Polygon = new Polygon(); polygon.addRing(arrPoints); polygon.spatialReference = extent.spatialReference; Graphic(event.target).geometry = polygon; mapEditTool.activate(EditTool.MOVE|EditTool.EDIT_V ERTICES, [Graphic(event.target)]);
var myEditTool : EditTool = new EditTool(myMap) // make sure you pass in the map object myEditTool.activate(EditTool.MOVE, [myGraphic]); //where myGraphic is the newly created graphic(in your case with an extent geometry)
<!-- EditTool, again making sure you pass in the map object --> <esri:EditTool id="myEditTool" map="{myMap}"/> myEditTool.activate(EditTool.MOVE, [myGraphic]);
