Don't use a model, just create a script tool.You set a schema to define the featureclass and fields in the dialog wizard when adding the parameters to the tool.It uses that schema to create a polygon when you draw interactively. It has to exist, you are not defining a new featureclass.After you open the tool there is a hidden property to change the drawing style by right-clicking the input in the tool dialog for the template properties.It defaults to drawing a polygon, but you can change it to draw a box. It requires a line and then drag which is a bit strange but it enables you to draw a box at any angle. But you can right click again and set a horizontal property.You would use the feature to select other layers directly, I only printed the json dump and the extent to demonstrate that it is a polygon feature that can be used in other tools or in Python.
def button1Click(self, selection): # Import arcpy module import arcpy index = self.listbox.curselection() label = self.listbox.get(index) # Local variables: layer = label # Script arguments Feature_Set = arcpy.GetParameterAsText(0) if Feature_Set == '#' or not Feature_Set: Feature_Set = "in_memory\\{EDD8060B-E74A-42D1-93A5-7CB08285BA52}" # provide a default value if unspecified # Local variables: CHS_Chart_Extents__3_ = Feature_Set CHS_Chart_Extents = layer # Process: Select Layer By Location arcpy.SelectLayerByLocation_management(CHS_Chart_Extents, "WITHIN", Feature_Set, "", "NEW_SELECTION") arcpy.RefreshActiveView()
from json_schema import Schema, AnyInteger my_schema = Schema([u"set-temp", {u"degrees": AnyInteger}]) if my_schema.validate([u"set-temp", {u"degrees": 10}]): print "Valid!"
The featureset is part of the ArcGIS toolbox parameters. It does not use TKinter at all.Your code attempts to use objects only available using a full AddIn. http://resources.arcgis.com/en/help/main/10.1/index.html#//014p0000001q000000You can use Tkinter to draw rectangles on a Tkinter window, but not the ArcMap window, so the coordinates will not be transformed to map units. The message queues between ArcGIS and TKinter are also not the same. That is what AddIns are for. Then you do have access to the ArcMap message queue and can detect all the mouse events such as the code you have pasted.My solution is for the case when you want to select a box interactively at the start and then run a script, not using the AddIn objects. Since you can add a script tool as a button, this is almost equivalent to Avenue tools we were use to, and it is easy to implement.http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=Feature%20sets%20and%20record%20setsThe Esri example concentrates on modelbuilder, but it can work in simple tools just as well.Create a tool and add a parameter. Set it to featureset. Set a schema that is a polygon featureclass.When you run the tool, open the properties to set drawing rectanglesDraw one or more rectangles and start the toolIn your script collect the polygon featureset entered interactively when the tool is runThis is just like an on-the-fly featureclass but in memory# DemoBox # draw a box interactively and report extent import arcpy fSet = arcpy.GetParameter(0) desc = arcpy.Describe(fSet) # print a JSON representation, version 10.1 arcpy.AddMessage(str(desc.pjson)) # print the extent of each box version 9.3+ for row in arcpy.SearchCursor(fSet): arcpy.AddMessage(str(row.shape.extent))
At the start of a script you can use the FeatureSet input type in a dialog.You need to have a template featureclass to refer to, in this case a polygon, as a layer to define the symbol to draw.Then when you run the tool you can interactively draw one or more polygons or rectangles just like using the draw tools.In the script you can pick up the geometry object if it was the first parameter and use it inRecSet = arcpy.GetParameter(0)This has been available since 9.3You would have to run the tool again to repeat.If you want more control then 10.1 AddIns will give you access to the message queue of mouse clicks, and tracking.But AddIns are significantly more trouble, so try the featureset first.
def button1Click(self, selection): def __init__(self): self.enabled = True self.cursor = 1 self.shape = 'Rectangle' def onRectangle(self, rectangle_geometry): #"""Occurs when the rectangle is drawn and the mouse button is released. #The rectangle is a extent object.""" # Extent of the feature extent = rectangle_geometry mxd=arcpy.mapping.MapDocument("CURRENT") # Set the workspace # env.workspace = mxd index = self.listbox.curselection() label = self.listbox.get(index) # Local variables: layer = label df = arcpy.mapping.ListDataFrames(mxd)[0] # Create a search cursor from layer # sCur = arcpy.SearchCursor(layer, '"CNTY_NAME" = \'Orange\'') # Fetch each feature from the cursor and examine the extent properties # for row in sCur: geom = row.shape ext = geom.extent # or row.Shape.extent # Create an Array object. #The DataFrame extent object is converted into a polygon feature so it can be used with the SelectLayerByLocation function. dfAsFeature = arcpy.Polygon(arcpy.Array([df.ext.lowerLeft, df.ext.lowerRight, df.ext.upperRight, df.ext.upperLeft]),df.spatialReference) arcpy.SelectLayerByLocation_management(layer, "INTERSECT", dfAsFeature, "", "NEW_SELECTION")
