Ik volg de les Voorspel overstromingen met unit hydrographs | Learn ArcGIS<\/A> en bij de sectie "Maak een Unit Hydrograph: Bereid de Unit Hydrograph-tabel voor," #13, krijg ik deze foutmelding: <\/P><\/P>FOUT 002717: Ongeldige Arcade-expressie, Arcade-fout: Puntkomma of nieuwe regel verwacht, Scriptregel: 1<\/P>Mislukt om uit te voeren (CalculateField).<\/P><\/P>Is er iets mis met de code !Count! * 30 * 30? <\/P><\/P>Dank u,<\/P>Erica<\/P><\/BODY><\/HTML>
<\/P>
Dank u,<\/P>
Hi Erica Price
David is correct. This is an error in the lesson:
For Arcade you should use:
$feature<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Count"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">*</SPAN> <SPAN class="number token">30</SPAN> <SPAN class="operator token">*</SPAN> <SPAN class="number token">30</SPAN> <SPAN class="comment token">// or</SPAN> $feature<SPAN class="punctuation token">.</SPAN>Count <SPAN class="operator token">*</SPAN> <SPAN class="number token">30</SPAN> <SPAN class="operator token">*</SPAN> <SPAN class="number token">30</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
You can also change it to Python and use the formula mentioned in the lesson:
!Count! <SPAN class="operator token">*</SPAN> <SPAN class="number token">30</SPAN> <SPAN class="operator token">*</SPAN> <SPAN class="number token">30</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
Looks like Python Field Calculator syntax?
I don't use Arcade unfortunately, but the documentation suggests a syntax like:
$feature["fieldname"] * 30 * 30
Thank you Erica, David, and Xander. We will make this fix for our next lesson release!
