I am trying to load a cacheDataset (name?) that was created using the MapCookerClass as shown in the Multithreaded MapCruncher example at the URL below. In arcMap it is possible to connect/add this cache using the Add Data dialog. The ArcEngine dialog does not seem to support this structure so I am trying to do it programmatically. Do I use a rasterWorkspace to open and connect to this data? Or, do I need to use something like the DynamicCacheLayerManager? The latter appeared more likely, but it looks like it is assuming you already have that layer in the map. I am wanting to add a new layer to the map from the previously created cache for an offline scenario. Any help/examples would be greatly appreciated. http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/Sample_Multithreaded_MapCruncher/000100000mmm000000/
