Hello,I am having problems using an area of interest shapefile when caching an image service. ArcGIS seems to be ignoring the shapefile and is caching the entire dataset. Is there some other setting that needs changed besides adding the shapefile as an AOI?ThanksSarah WachManitoba Hydro
I changed the projection on my shapefile to match the service (the mosaic dataset is in UTM, but since I want to use the ArcGIS.com tiling scheme it is publishing the service in Web Mercator) It still isn't working. When you use an AOI polygon does it recalculate the estimated cache size?
