That's a fantastic solution, and I'd like to try it; however I don't have access to the datagrid code. I was wondering if there was any way to hyperlink field comments to open a pop up window containing the same comments.Thanks again,Kate.
Hi there,We have a widget in our web app that returns results in a datagrid. We do not have access to the source code, and the "Comments" field populates the grid in a single line (which can be quite long). As a work around, I am wondering if there is a way to click the attribute info in the "Comments" field (I can make the field a hyperlink field) and run a script from the hyperlink script dialog to pop open a window displaying the "Comments" attribute info (same info that was clicked).The hyperlink script dialog accepts JScript and VBScript, however I'm unsure how to approach this.Any suggestions would be appreciated,Kate.
... <div style="width: 650px; height: 400px"> <table id="billsGrid" dojoType="dojox.grid.DataGrid" sortInfo="2"> <thead> <tr> <th field="ConflictID" formatter="makeviewButton" width="20px">View feature</th> <th field="Oid" width="150px">OID</th> <th field="InVersion" width="150px">Version</th> <th field="ChangeType" width="150px">Change Type</th> </tr> </thead> </table> </div> ... <script type="text/javascript"> dojo.ready(function() { var conflictCollection ={"items":[{"InVersion":"GDP_OWN.DataEditing_1","ChangeType":"Delete","Oid":4614,"ConflictID":"1-4614-GDP_OWN.DataEditing_1"},{"InVersion":"GDP_OWN.DataEditing_2","ChangeType":"Update","Oid":4614,"ConflictID":"2-4614-GDP_OWN.DataEditing_2"}]}; var dataStore = new dojo.data.ItemFileReadStore({ data:conflictCollection }); var grid = dijit.byId("billsGrid"); grid.setStore(dataStore); }); function makeviewButton(id){ var strArray =id.split("-"); var oid =strArray[1]; var version =strArray[2]; var vBtn = "<div dojoType='dijit.form.Button'><img src='view.png'"; vBtn = vBtn + " width='18' height='18'"; vBtn = vBtn + " onClick=\"viewRow("+oid+", '"+version +"')\"></div>"; //alert(vBtn); return vBtn; } function viewRow(oid, version) { alert("oid=" +oid +"; version="+version); } </script>
