Here's a blog on how you can customize the look and feel of ArcGIS controls http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2010/05/20/Use-control-templates-to-customize-the-look-and-feel-of-ArcGIS-controls.aspxIt's similar steps except you choose FeatureDataForm
<Button x:Name="CancelButton" Content="Cancel" Grid.Column="0" HorizontalAlignment="Right" HorizontalContentAlignment="Center" Margin="0,0,12,0" MinWidth="75" MinHeight="22" Style="{TemplateBinding CommitButtonStyle}" Visibility="Visible" VerticalAlignment="Center" VerticalContentAlignment="Center"/>
... <Grid Height="166" Width="246"> <Grid.RowDefinitions> <RowDefinition Height="*"/> <RowDefinition Height="Auto"/> </Grid.RowDefinitions> <ScrollViewer Background="{x:Null}" IsTabStop="False" Padding="{TemplateBinding Padding}" Style="{StaticResource CustomScrollViewerStyle}" VerticalScrollBarVisibility="Auto"> <ContentPresenter x:Name="ContentPresenter" Margin="12,12,6,12"/> </ScrollViewer> <Grid Margin="0,8,0,8" Grid.Row="1"> <Grid.ColumnDefinitions> <ColumnDefinition Width="*"/> <ColumnDefinition Width="*"/> </Grid.ColumnDefinitions> <Button x:Name="CancelButton" Content="Cancel" Grid.Column="0" HorizontalAlignment="Right" HorizontalContentAlignment="Center" Margin="0,0,12,0" MinWidth="75" MinHeight="22" Style="{TemplateBinding CommitButtonStyle}" Visibility="Visible" VerticalAlignment="Center" VerticalContentAlignment="Center"/> <Button x:Name="CommitButton" Content="{TemplateBinding CommitButtonContent}" Grid.Column="1" HorizontalAlignment="Right" HorizontalContentAlignment="Center" Margin="0,0,12,0" MinWidth="75" MinHeight="22" Style="{TemplateBinding CommitButtonStyle}" Visibility="Collapsed" VerticalAlignment="Center" VerticalContentAlignment="Center"/> </Grid> </Grid>...
You can use Expression Blend and right-click on your FeatureDataForm and select "Edit Template" --> "Edit a copy...", then you will get the default control template for your FeatureDataForm. Switch to the XAML view and look for the "CommitButton" button. Jennifer shared a very good URL on how to do the styling in Blend, you can also look into that page.
