Arc Hydro Documentatie
https://community.esri.com/t5/water-resources-documents/tkb-p/water-resources-docs
Beschikbare Arc Hydro versies
Arc Hydro Versie
ArcGIS Pro
2.5 - 3.7
https://www.esri.com/en-us/industries/water-resources/arc-hydro/downloads#arc-hydro-for-arcgis-pro
ArcMap
9.3 - 10.8.x
https://www.esri.com/en-us/industries/water-resources/arc-hydro/downloads#arc-hydro-for-arcmap
Christine Dartiguenave
Esri Water Resources Team
Christine,
Thanks for the direct links for http URL download. Will you be posting up similar for the HEC developmental and beta builds--GeoHMS and GeoRAS?
Should we expect change/elimination of the MFT site?
Stuart
PS. Timothy Hales, Jim Barry, if Esri devs/product managers are going to mark things as "Official", the tag you provide them could use a little design work--an Esri branding to the icon, even different wording perhaps?
Not sure what control we get over the tag, but I can check on it. Thanks for the feedback.
For now we are planning on keeping both the download page and the mft site. We may post the beta builds location for HEC-GeoHMS and HEC-GeoRAS but the official releases will still be posted on HEC website.
Christine
Hi, I have installed ArcGIS v. 10.2.2.3552 successfully today, but I cannot find in the link provided the Arc Hydro for this version especifically. Which of the ones listed below should I install? Thanks in advance.
Ana
[To Parent Directory] 7/21/2014 2:54 PM <dir> 10.2.0.55 9/30/2014 6:31 AM <dir> 10.2.0.76 10/22/2014 12:33 PM <dir> 10.2.0.82 11/5/2014 8:07 AM <dir> 10.2.0.85 12/19/2014 10:17 AM <dir> 10.2.0.88 1/15/2015 12:31 PM <dir> 10.2.0.93 1/20/2015 4:40 PM <dir> 10.2.0.94 1/22/2015 2:48 PM <dir> 10.2.0.96 8/14/2014 11:13 AM <dir> RAPID
Ana Simoes, *,
The 10.2.0.96 build is the latest for the 10.2.x builds--probably best to install that.
Now the last working build for 10.2 and 10.2.x versions is here
yellow.esri.com - /archydro/archydro/Setup/10.2.x/10.2.0.117/
build 10.2.0.117, 6/2/2015
Hello Every one,
I am installing archydro 10.2 version but when i start the installation i get app frame work error . Can any one provide guide line regarding this ..
The readme.txt inside the ArcGIS Pro folder (http://downloads.esri.com/archydro/archydro/setup/Pro/readme.txt ) must say:
1. Extract the zip file to the location where you want to install ArcHydroPro
2. Edit the file archydropython.pth so that the path points to the location of ArcHydro\Scripts\ArcHydro (e.g. C:\Tools\ArcHydroPro\Scripts\ArcHydro).
3. Copy the edited archydropython.pth to %ProgramFiles%\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages.Otherwise you won't be able to run ArcHydro from ArcGIS Pro. ArcHydro uses Python from the default conda environment arcgispro-py3.
Hi Christine - are the 10.5.x toolbox tools compatible with 10.6.x? If not, would you have an idea as to when that build would be available? Also, can you tell me if the build:
yellow.esri.com - /archydro/archydro/Setup/Pro/ArcHydroPro2.0.10/
will work for 2.1.x ?
Thanks-
David
The quick answer is that they should be compatible (both Pro and 10.6). We are in the process of testing them and adjusting them to take advantage of the new capabilities.
Great, thank you . . .
Hi Christine,
I have installed the latest version of Arc Hydro for ArcGIS Pro. The commands seem to work fine from the toolbox, but is it possible to call the commands from a python script? In the ArcGIS desktop version, we would just use "Import ArcHydroTools" to setup the environment. However, this does not work in Pro. Is there a different module, or is this functionality not yet available?
Many thanks!
I found the 10.6 versions. Are they working?
Hi Christine, when I try to install the latest version of Hydro for Pro on Pro 2.1.2, I get an error that I need Pro 1.2 or greater. Has anyone else had this issue and gotten around it?
Mark
Mark,
I cannot duplicate the issue.
Basically the install package retrieves the RealVersion value from the following registry key.
HKEY_LOCAL_MACHINE\SOFTWARE\ESRI\ArcGISPro
It then checks the value to see if it is >= 1.2.
So, for some reason, the value it is retrieving is either null or less than 1.2.
You can check whether the key is there or try to run the installer with logging turned on and send us the log file.
Here is the command: msiexec /i
Example: msiexec /i C:\Data\ArcHydroToolsforArcGISPro.msi /l* C:\Data\msi.log
Hi ArcHydro Community
I've been using ArcGIS 10.3.1 for quite a while with ArcHydro 10.3.0.78 and due to my python package that I've developed have been reluctant to upgrade to ArcGIS 10.6. I wanted to find out from Christine Dartiguenave if there are any major changes from ArcHydro 10.3 to 10.6 version that would break my existing code, before making the leap.
No major code changes. However there are a few issues with some of the underlying functions at 10.6/10.6.1.
As we are testing Arc Hydro, we are working with the developers to get those resolved. So I would wait a little before upgrading until a
“raster” patch is released.
Hi Christine Dartiguenave
Thanks for the update, really appreciate you taking the time to get back to me. I'll wait a bit longer then thanks
We have updated our ArcHydro to version 10.6 with ArcMap. Our current documentation was from when the tools were on a toolbar. Is there updated documentation for the Toolbox Version of AH? (We've found this: http://downloads.esri.com/archydro/archydro/tutorial/doc/arc%20hydro%20tools%202.0%20-%20tutorial.pdf ) but it has a date of 2011. Thanks in advance!
I am also attempting to utilize ArcHydro with ArcMap 10.6.0 and am finding it challenging because of a lack of a tutorial that matches the current tool set and workflows. I don't have experience with the prior versions of ArcHydro but am well versed in ArcGIS. Would it be possible to get current training materials since no ArcHydro classes are currently scheduled?
We are not planning to update the basic step by step tutorial. I started doing just that and with more than 250 tools and many options on how to implement your workflows, it quickly became a nightmare to develop and maintain. So now our objectives are to try to document each tool in the Python toolbox itself and to develop some workflow oriented documentation, similar to what we have done for stormwater. We are planning to revisit the main terrain preprocessing workflows and are finalizing an updated stormwater and a new flood oriented document.
If there are any area/workflows that you would like to see documented beside those?
As for the Arc Hydro training, you can contact Dean Djokic (ddjokic@esri.com). He schedules and teaches them, and will be conducting 2 workshops at the Water Conference next year (on stormwater and on flood).
Help please.
Downloaded and attempted to install 2019.04.01 ArcHydroTools10.6.0.34 for use with Windows 2016 server, ArcGIS Desktop 10.6.1 (Citrix environment). Error message received. Why does this require .NET 3.5 (incl 2.0 and 3.0) be installed when that is not a system requirement for ArcGIS Desktop 10.6.1? The requirement is .NET 4.5 or higher.
Hi ArcHydro team! I am new to Arc Hydro, but definitely well-versed in ArcGIS. I am attempting to use Arc Hydro for stormwater catchment delineation. As I follow the Stormwater Processing guidance, it appears that I am missing some tools (I've download the toolbox for both Pro and ArcMap...). Should this be happening? Why would some of the tools be missing in the toolbox?
I specifically am looking for some some of the feature editing tools:
1. Create Pipe Outlets
2. Create Overland Flow Connectors
Thanks so much!
We are in the process of migrating/testing the Arc Hydro Tools from ArcMap into Pro, this is why you only see a subset in Pro. In addition, some of the capabilities needed to support the stormwater processes are not yet available in Pro (tracing our hydro network) and should be available at the beginning of next year. So at this time, you need to use the Arc Hydro Tools Python in ArcMap for stormwater.
Thank you Christine, I will move forward with ArcMap
Hi Christine, I just purchased ArcGIS and the ArcHydro Tools download link for ArcMap 10.8 isn't available and the present ones aren't backwards compatible in ArcMap 10.8. I'm new to ArcGIS Pro with most of my projects in ArcMap. Kindly help. A download link for Arc Hydro Tools 10.8 will be highly appreciated.
Is there a way to silently install the MSI for ArcGIS Pro without receiving the Esri ArcGIS Add-In Installation Utility prompt to approve the install? I've tried using the /qn switch on the install command, but I'm still receiving the prompt. We have a few dozen computers that will be receiving this add-in and we'd like to deploy it silently via Microsoft Endpoint Configuration Manager.
Any version after 2.0.194 included will be silent:
http://downloads.esri.com/archydro/ArcHydro/Setup/Pro/ArcHydroPro2.0.194/
Thank you, Christine. That solved the issue!
Hi, may I ask what particular ArcHydro should I download for ArcGIS Pro v.2.5.0? Thank you!
Is there a version of ArcHydro that will run in the ArcGIS Pro 3? With the change in code for this release, I suspect that the old versions will not work.
Sean
