Hello FLBB,I changed you if statement. This one will skip files like about.xmlfiles.txt (which is possible). It will also be case insensitive (accepting both '.xml' and '.XML' files).I think you also need an if statement to see if 'IsNullable' actually appears in the xml file.from xml.etree import ElementTree as et import os workspace = r"C:\test" for dirpath, dirnames, filenames in os.walk(workspace): for filename in filenames: if filename.lower().endswith('.xml'): tree = et.parse(os.path.join(dirpath, filename)) targetTag=tree.find('.//IsNullable') if targetTag is not None: targetTag.text = 'false' else: print "No IsNullable tag was NOT found in: "+filename tree.write(os.path.join(dirpath,filename))I not 100% confident this methodology will actually change the Nullable field property. I worried that you are only changing the metadata and the actual field property (in the '.dbf') is not changing. Can you actually put null values into a field of one of the shapefiles you have modified?Let be know how it goes!
Nice solution FLBB! Does it work when you open that file in ArcMap?This should find all xml documents in a given directory.import os for aFile in os.listdir(r"C:\Path\To\Data"): if aFile.lower().endswith(".xml"): print aFile #Do stuff to xml files
