Hey Jeff Pace - also trying to get a LizardTech WMS service running. I am trying to add from their demo page using Arcgis Api for JavaScript 3.14, but no dice. Any ideas?
<SPAN class="keyword token">var</SPAN> wmsTest <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">WMSLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fdemo.lizardtech.com%2Flizardtech%2Fiserv%2Fows" target="_blank">http://demo.lizardtech.com/lizardtech/iserv/ows</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> format<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"png"</SPAN><SPAN class="punctuation token">,</SPAN> resourceInfo<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> copyright<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"lizardtech"</SPAN><SPAN class="punctuation token">,</SPAN> description<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"test"</SPAN><SPAN class="punctuation token">,</SPAN> extent<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Extent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">81.248255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">29.572644</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">82.908008</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">26.740052</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN><SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> featureInfoFormat<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"text/html"</SPAN><SPAN class="punctuation token">,</SPAN> getFeatureInfoURL<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fdemo.lizardtech.com%2Flizardtech%2Fiserv%2Fows" target="_blank">http://demo.lizardtech.com/lizardtech/iserv/ows</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN> getMapURL<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fdemo.lizardtech.com%2Flizardtech%2Fiserv%2Fows" target="_blank">http://demo.lizardtech.com/lizardtech/iserv/ows</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN> layerInfos<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">WMSLayerInfo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Florida_Mosaic"</SPAN><SPAN class="punctuation token">,</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Florida_Mosaic"</SPAN><SPAN class="punctuation token">,</SPAN> queryable<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> showPopup<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> spatialReferences<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">4326</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> version<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"1.3.0"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> visible<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
<mapservice label="2011 Aerials" type="wms" catalog="0" visible="true" alpha="1" icon="assets/images/icons/i_shuttle.png">http://www.mymanatee.org/arcgis/services/base-map/aerials-2011-wms/MapServer/WMSServer?request=GetCapabilities</mapservice>
if (mapServiceInfo.type === "wms") { var layerInfo = new esri.layers.WMSLayerInfo({name:mapServiceInfo.layer,title:mapServiceInfo.layer,spatialReference:new esri.SpatialReference({wkid:102100})}); var resourceInfo = { extent: new esri.geometry.Extent({"xmin":-9214584.290114,"ymin":3145848.430227,"xmax":-9133734.228469,"ymax":3208214.597832,"spatialReference":{"wkid": 102100}}), layerInfos: [layerInfo], version:"1.3.0" }; layer = new esri.layers.WMSLayer(mapServiceInfo.url, { resourceInfo: resourceInfo, id: mapServiceInfo.label, transparent: parseFloat(mapServiceInfo.alpha), visible: mapServiceInfo.visible, visibleLayers: [mapServiceInfo.catalog], type: "wms" });
That doesn't seem right. Are you using the WMSLayer class? Graphics and Feature Layers should always draw on top of dynamic (including WMS) and tiled services.
