When I click on the "Create Space Time Cube" tool, it doesn't open it. Although other tools like "Optimized Hot Spot Analysis" works fine. What might be the problem?
So they are NOT projected... use the Project tool
Project—Data Management toolbox | ArcGIS Desktop
you will know you have done the right thing since 'Project' makes a new file and you have to provide a the new name
All four numbers are within the range of -180 to 180 and -90 to 90 decimal degree. See attached.
Thanks.
the question remains, is the file in a projected coordinate system? Check the file's properties and examine the 'extent' if the extent looks like it has big numbers and not those like one would expect with decimal degree data, then it is probably projected. If the data are in the range of -180 to 180 and -90 and 90, then it is not projected.
If you can rule that out, then the problem lies elsewhere, and since nothing seems to have been of use so far, you might want to await other suggestions
At first, I right clicked the map and in the properties and coordinate system tab, I chose those coordinate systems.
But now, I used the "Project" Tool and chose the "Current Map" for the output coordinate system. But, doesn't work either.
Yes, that's checked as well . I think it is a software issue!
installed is one thing... did you go to Customize, Extensions and if it is a separate extension, then it needs to be toggled on
I use ArcGIS Desktop 10.5.1. I double checked and still doesn't work!
Although, the extensions are installed.
you don't specify which software..
All are fine in Pro
