I know I'm extremely late to the party, but I'm exploring the possibility of connecting RealWare with ArcGIS Pro too. Was there a solution to doing this for you all in Wyoming?
Wyoming does not use GeoWare anymore. We will be going to Matix within the next few months.
Karen Bowman
GIS Mapping Specialist
Albany County Assessor's
Laramie, WY 82070
As John Lucotch mentioned, if GeoWare is built off of SQL Server, then you could make a database connection to the SQL Server database and see the tables in there. Are you attempting to make an ArcMap Join to tie the 2 tables together? Pls advise.
Regards,
Robert LeClair
Esri-Denver
Danette - In briefly researching your question, there is quite a bit about the State of Wyoming Department of Revenue's Conversion Standard for ArcGIS. Please see the following brief for details: http://pdf.aminer.org/000/295/153/conversion_of_high_level_information_from_scanned_maps_into_geographic.pdfFurther, it would seem an add-on called GeoWare - http://www.coloradocustomware.com/Geoware.aspx - may be what you're looking to do. Do you have access to GeoWare? Please advise.Regards,Robert LeClairEsri-Denver
