@TKONG - do you think the problems you identified could cause me difficulty later on?
One thing I noticed when I looked up Ghana coordinate systems, and that led me to ask whether the first set could be overlaid over other data, is that there's a version that uses a "Gold Coast foot". It certainly looks like the layer is 1/3 the size of the other data! Leave it undefined. Add and the other data to ArcMap. Try setting the data frame's coordinate system to Accra Ghana Grid and see if they line up. You should get a gcs/datum warning message. Melita
---ExtentsTop: 756142.379950 mRight: 1142656.619454 mLeft: 690629.179290 mBottom: 74790.443758 mProjected Coordinate System: Ghana TMProjection: Transverse_MercatorFalse_Easting: 900000.00000000False_Northing: 50000.00000000Central_Meridian: -1.00000000Scale_Factor: 1.00000000Latitude_Of_Origin: 4.66666667Linear Unit: MeterGeographic Coordinate System: GCS_Clarke_1866Datum: D_Clarke_1866Prime Meridian: GreenwichAngular Unit: Degree----Top: 769664.186871 ddRight: 1142674.650690 ddBottom: 57841.861131 ddLeft: 650523.913583 ddGeographic Coordinate System: GCS_WGS_1984Datum: D_WGS_1984Prime Meridian: GreenwichAngular Unit: Degree---Any help greatly appreciated!
The 2nd extent looks very similar to the first. What happens if you redefine (not reproject) the 2nd set to use the same coordinate system? If that doesn't work. Can you overlay the first set (that's using Ghana TM) with a 3rd set of data like general country boundaries? The Ghana TM definition that you have doesn't match other definitions that I've seen for Ghana data. Melita
