I would like to create some custom lots without using the built in Block types using python.
Can someone provide some hints?
Thanks!
-Robert
This creates a simple 500mx500m rectangle.
<SPAN class="keyword token">from</SPAN> scripting <SPAN class="keyword token">import</SPAN> <SPAN class="operator token">*</SPAN> <SPAN class="comment token"># get a CityEngine instance</SPAN> ce <SPAN class="operator token">=</SPAN> CE<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#vertex array xyz</SPAN> myVertices <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">500</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">500</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">500</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">500</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">if</SPAN> __name__ <SPAN class="operator token">==</SPAN> <SPAN class="string token">'__main__'</SPAN><SPAN class="punctuation token">:</SPAN> myShape <SPAN class="operator token">=</SPAN> ce<SPAN class="punctuation token">.</SPAN>createShape<SPAN class="punctuation token">(</SPAN>None<SPAN class="punctuation token">,</SPAN> myVertices<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
