It is something that we will be fixing soon but here is how to geocode the address table until we have a fix.1. Click the mailbox button with a table added to ArcMap but also make sure you have the table selected in the TOC or you will get the same error.2. Browse to the table in the Catalog window in ArcMap, right click on the table, and select �??Geocode Addresses�?��?�3. Use the GeocodeAddresses GP toolBrad
Brad,
Just upgraded to 10.2.2. and issue is still there. You said it was something that will be fixed soon. Any update on the fix?
This is not fixed for 10.2.2 and we target fixing it for 10.3 but there are multiple ways to batch geocode from within ArcMap to work around this issue:
1. Click the mailbox button with a table added to ArcMap (Drag and drop it into the TOC) but also make sure you have the table selected in the TOC or you will get the same error.
2. Browse to the table in the Catalog window in ArcMap, right click on the table, and select "Geocode Addresses"
3. Use the GeocodeAddresses GP tool under "Toolboxes">"System Toolboxes">"Geocoding Tools" in the Catalog window in ArcMap.
Brad
Thanks Brad,
I’ve started using your option #2 below and it works fine. The only difference is I have to manually add in the geocoded feature class to the map after the matching is done – but not a huge inconvenience. I’m just glad I don’t have to go back to 10.2 or rebuild my locators!
Thanks for the info and have a good day.
Hal Stringer
Computing Support Manager
<http://www.tminc.com/> www.tminc.com
(407) 740-3023 - Phone
(407) 740-0613 - Fax
