This was what I had originally understood, but Esri support explained otherwise (the 1000 credits to geocode 40 records was straight from Esri support... Not that getting a dozen totally different responses from a dozen different techs is anything new).I'm still testing alternatives, because we have no immediate plans (or money) for purchasing credits.
So if you hypothetically started with 1,000 credits and you only geocode to use credits, you could geocode 25,000 records.
PMoore: Can you please post that XML file that Kara from ESRI provided you? I've tried the steps in the link you provided, per the suggestion of another post-er, but that didn't work for me. I'd like to try what Kara offered you. Thank you.
I don't know if anyone in this thread is still having issues but this is what I did and it worked just fine for me.I followed the below workflow for a client using a Windows 7 PC with ArcGIS 10 SP 5:1. Go to http://support.esri.com/cn/knowledgebase/techarticles/detail/40542 and follow the workflow to Disable Default Locators that connect to ArcGIS.com2. Go to http://support.esri.com/fr/knowledgebase/techarticles/detail/40802 and follow the workflow to Add the World Geocoding Service to ArcMapThis worked just fine for me, but you should probably note that using this service for batch geocoding will require ArcGIS online credits in the near future if not already. But if you are just using it for locational purposes inside ArcMap, I think it would probably work just fine. Also, I would recommend, if you have good local data, to build your own locator.Good Luck,
You don't need the XML file. the Geocoding and Geosearching in ArcGIS that have been in use for a long time are no longer available. These have been replaced with the Single World Geocoding service. Information on the retirement is here: http://blogs.esri.com/esri/arcgis/2013/04/08/legacy-geocoding-and-routing-services-at-httptasks-arcgisonline-com-will-be-retired-on-december-31-2013/What you have to do to add Geosearch and Geocoding to ArcMap is here:http://resources.arcgis.com/en/help/arcgisonline-content/index.html#//011q0000000t000000and here:http://support.esri.com/fr/knowledgebase/techarticles/detail/40802
This helps explain the credits:http://www.esri.com/software/arcgis/arcgisonline/credits
This is correct.I spoke with Esri support today and learned that batch geocoding using ArcGIS Online geocoding services will now require the purchase of credits. I also learned that the thousand or so credits that my account started with are enough to geocode around 40 records. Eminently useful.On that note, I'm searching for alternatives, so if anyone knows of good geocoding services available from other sources for free, I'd love to know.
I just went through the process of getting the new world geocoding service but when I tried using it to batch geocode an excel file I got an error message. I did a little more research and it seems that now if you want to batch geocode in Arc Desktop you have to have to pay for a subscription to Arc Online. Can someone verify this for me?
There's a new default locator XML file you have to download-once you get the new file, here's what to do with it (it's an e-mail from ESRI Tech Support:This is Kara M. with Esri Technical Support regarding incident #1240876. The reason you are experiencing this error message is that we have officially retired the tasks address locators. More information regarding the deprecation of the tasks locators can be found here:To resolve the initial issue of the error message you are receiving, please follow the steps below:1. Close out of all ArcMap and ArcCatalog sessions. 2. Download the attachment from this email.3. Navigate to C:\Program Files (x86)\ArcGIS\Desktop10.0\Locators and rename the DefaultLocators.xml to DefaultLocatorsOLD.xml. 4. Copy and paste the attached file into this folder. 5. Open ArcMap and retest. HowTo: Add the World Geocoding Service to ArcMap for batch geocodinghttp://support.esri.com/fr/knowledgebase/techarticles/detail/40802
Thanks. I was able to follow those instructions in ArcMap 10. Is it your understanding that the World Service always requires a sunscription and credentials?
Thanks for taking the time to post. Unfortunately the first link is for an XML file that removes ALL online locators. The second link leads to an article that eventually takes me to this page http://support.esri.com/en/knowledgebase/techarticles/detail/40802 but I cannot follow those instructions because I have Arcmap 10.0.
I believe the file in question is available here: http://support.esri.com/cn/knowledgebase/techarticles/detail/40542.A discussion of the changes is also posted at: http://blogs.esri.com/esri/supportcenter/2013/01/04/changes-to-default-geocoding-locator-options-at-arcgis-for-desktop-10-1-sp1/.
