Hey guys, after trying another run, i found where the problem is. You must keep the basin name e.g. Subbasin155 as the same as the basin table header name e.g. basinheader155. Which means in the process of running HEC-GeoHMS, its better not change anything that being set as default...
It's 2018 guys... how are you doing? I am still facing with this same problem, has anyone been able to solve it? Thanks!
Hi, i have done the same suggestions above, but problem is still there, have you solved your problem?Thanks.
Hi, I've done what Michael had suggested. But it still didn't work on the project that I am doing. Does anyone have another suggestion? Thanks.
Dear All,
I hope everyone is doing fine.
I am new to HEC-HMS. Everything went fine until map to Hec-Hms unit in Hecgeohms toolbar in arcgis 10.2.
the problem is whenever i click on map to HEC-HMS unit the problem pop up BasinHeader table could not be found. All tables are in main geodatabase. So I wanted to ask how i can solve this problem? Can I make basin header table on my own? Can some one share his basinheader table so I can follow on same lines. Or under hat name HEcgeohms create basin header table because Hecgeohms create lot of tables so can you guys tell me under which name it is so may be i can import it in arcmap manulay. pleases help me I will be thankful to you guys.
Thanks in Advance
I did something that actually worked to me.
You should export the Basin Header to the Geodatabase that you are using. It could work
See you
FYI,I've been getting the same error and it's starting to drive me nuts. I know where the BasinHeader table is, it's added to the map, I've opened it to verify that it's real, and I specified the location of it using the Data Management tool in the GeoHMS toolbar. Still get the same error every time, and as a result I need to manually input the geometry information in HEC-HMS. Kinda defeats the purpose of using the toolbar. So any updates from someone with a fix are still welcome.ThanksGH 12/12/2013 Using version 10.1
