Mark,You may be able to only have one label function if you make use of the column that's passed in. In the mxml you could set the dataField on the column and refer to that in the label function.
private function labelOf(fullfieldname:String):Function { return function (item:Object, column:DataGridColumn):String { return item[fullfieldname]; }; } private function sortOf(fullfieldname:String):Function { return function (obj1:Object, obj2:Object):int { if(obj1[fullfieldname] < obj2[fullfieldname]) { return -1; } else if(obj1[fullfieldname] > obj2[fullfieldname]) { return 1; } else { return 0; } }; } <mx:DataGridColumn headerText="Roll Number" labelFunction="{labelOf('Parcels.ARN')}" sortCompareFunction="{sortOf('Parcels.ARN')}"/> <mx:DataGridColumn headerText="Name" wordWrap="true" labelFunction="{labelOf('LinkedTable.dbo.ASYST_NamesTable_PrimaryOnly.FullName')"} sortCompareFunction="{sortOf('LinkedTable.dbo.ASYST_NamesTable_PrimaryOnly.FullName')}"/>
Try:<mx:DataGridColumn id="rnc" labelFunction="labelFunction" headerText="Roll_Number" />labelFunction is a property of DataGridColumn. It should be set to the name of the function, so it could also be:labelFunction="myLabelFunction" if myLabelFunction was the function name.
Try using this:http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/mx/controls/dataGridClasses/DataGridColumn.html#labelFunctione.g. private function labelFunction(item:Object, column:DataGridColumn):String { return item["LinkedTable.dbo.ASYST_NamesTable_PrimaryOnly.FullName"]; }
