Hi, As a beginner I am having a lot of problems with Data Frame and the Grid. When I started to draw these maps my entire map fit quite nicely into the layout view and so then I used Export Map I got Figure 1 wherein the entire layout view area was covered by my figure. Bu then I realized that i had missed some points on the east so I extended my figure eastwards. In doing so I got a lot of bank spaces in the north as the map was extending both X and Y axis proportionally. So I used Data Frame Properties ->Fixed Extend and Chose about 13.5 degrees in the north. Now the figure was shortened to about half of the layout and when I exported it it looked very small with a lot of blank spaces around it. I tried to go back to my old layout but I couldnt do that either.
Any help would be much appreciated.
Thanks a lot!
Helga
