var _sort = function(field) { return function(a, b) { var x, y; x = a.attributes[field]; y = b.attributes[field]; return (x < y) ? -1 : 1; }; }; theFeatureSet.sort(_sort('Your Field Name'));
theFeatureSet.sort(function(a,b) { return a.attributes.fieldName - b.attributes.fieldName; });
SamirI think what they mean "dynamic layers" as a property of the service. NOTE: this is a property of the ArcGIS REST Services Directory for your MapServiceSupports Dynamic Layers: trueI am not too sure if this is the correct way for you to follow. I just tried implementing what you are trying to do and had no success. However, in my case, the queries ran correctly with no errors but the featureSet was not "ordered by" the field that I indicated. Sometimes it would actually change my result set based on OBJECTID ASC or DESC order (which I had indicted in the orderByFields param) but it NEVER sorted by the field that I indicated. I am not sure if I was implementing it correctly ... but my results were inconclusive. I tried it with both a featureLayer.selectFeatures and an MapService URL via a QueryTask.execute. No luck. Sorry, I wish I could be more of help but I am also stuck here with no way to order my results other than what was suggested by Steve (array.sort).Below is a "watered-down" version of the two different sets of code that I used for testing: //TEST 1: Use existing featureLayer to perform query var selectQuery = new esri.tasks.Query(); selectQuery.geometry = geometry; selectQuery.orderByFields = ["MEASURE ASC"]; pointFeatureLayer.selectFeatures(selectQuery, esri.layers.FeatureLayer.SELECTION_NEW); //TEST 2: Use QueryTask to query MapServer Layer var queryTaskOperation = new esri.tasks.QueryTask("http://myserver:6080/arcgis/rest/services/FeatureServices/TestEditngService/MapServer/0"); query.outFields = ["OBJECTID", "REACHCODE", "REACHRESOLUTION", "MEASURE", "EVENTTYPE"]; var query= new esri.tasks.Query(); query.geometry = geometry; query.orderByFields = ["MEASURE DESC"]; query.returnGeometry = true; queryTaskOperation.execute(query, function (featureSet) { alert("total features = " + featureSet.features.length); //NOTE: I step through the code and can see what the returned featureSet.features array looks like here! }, function (e) { alert("Error during query task"); });
myFeatureLayer.queryFeatures(query, function(featureSet) { featureSet.features.sort(function(a, b) { return a.attributes[myField] - b.attributes[myField]; //ascending order }); });
SamirWhat type of layer are you performing your query on and what version of ArcGIS Server? According to the documentation you have serveral requirements that must be met in order to use orderByFields query param. I have listed them below: 1) orderByFields is only supported on dynamic layers and tables where supportsAdvancedQueries is true2) Requires ArcGIS Server service version 10.1 or greater (As of v2.6)
Have you looked at the esri.tasks.query.orderByFields method? Here is the help documentation linkhttp://help.arcgis.com/en/webapi/javascript/arcgis/jsapi/#Query/groupByFieldsForStatisticsYou will want to be sure to read the specific information about this method since it requires layers that support advanced queries.You might also want to look at the StatisticDefinition class (esri.tasks.StatisticDefinition) to see if you can use the statistics type of "count" to return your unique list of values for example. You can use either the esri.tasks.QueryTask or esri.layers.FeatureLayer.queryFeatures to pass in the esri.tasks.query object to perform your query. The results will give you a FeatureSet that you can further manipulate as needed (as indicated above).Not sure if this is what you need but figured it is worth a try. Good luck
if (rate == "higher rates") { //retrieved from the user selection using a combobox fieldOrderString = '["' + indv + ' ASC"]'; //'indv' is the indicator selected } else if (rate == "lower rates") { fieldOrderString = '["' + indv + ' DESC"]'; } query.orderByFields = fieldOrderString; queryTask.execute(query, function(featureSet) { for ( i = 0; i < numg; i++) { //'numg' is the number of features that user would like to be selected var features = featureSet.features; } });
stateFeatureLayer.queryFeatures(query, function (featureSet){ //'stateFeatureLayer' is the feature layer featureSet.sort(function(a,b) { return a.attributes.All_CBR - b.attributes.All_CBR; }); });
