I'm using version 100.4.0 of arcgis and I get sometimes random crashes with the following stacktrace :
E/AndroidRuntime: FATAL EXCEPTION: Thread-31
Process: xyz, PID: 32132
com.esri.arcgisruntime.ArcGISRuntimeException: Invalid argument
at com.esri.arcgisruntime.internal.jni.CoreRequest.nativeGetCanceled(Native Method)
at com.esri.arcgisruntime.internal.jni.CoreRequest.h(SourceFile:213)
at com.esri.arcgisruntime.internal.j.b$2.run(SourceFile:199)
at com.esri.arcgisruntime.internal.b.g.b(SourceFile:45)
at com.esri.arcgisruntime.internal.b.e.a(SourceFile:115)
at com.esri.arcgisruntime.internal.b.c.done(SourceFile:44)
at java.util.concurrent.FutureTask.finishCompletion(FutureTask.java:383)
at java.util.concurrent.FutureTask.set(FutureTask.java:234)
at java.util.concurrent.FutureTask.run(FutureTask.java:274)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
at java.lang.Thread.run(Thread.java:764)
It happens without changing any code when moving on the map (touch), loading the map or clicking. The data set is the same everytime and I have no idea how to reproduce it.
Do you know what can cause this issue ? And could it be possible to have more details on the Exception returned by ArcGIS because it's really not helpful.
Thank you
