def get_max_mode_candidate(path_to_dataset, value_field): mode_dict = {} with arcpy.da.SearchCursor(path_to_dataset, [value_field]) as get_mode: for record in get_mode: val = record[0] if val in mode_dict: freq = mode_dict[val] freq += 1 mode_dict[val] = freq del freq else: mode_dict[val] = 1 max_count = 0 mode_candidates = [] for val in mode_dict: if mode_dict[val] > max_count: mode_candidates = [val] elif mode_dict[val] == max_count: mode_candidates.append(val) else: pass max_mode = max(mode_candidates) return max_mode
Hi.I have this problem.In a Spatial Join the merge rules allow you to specify how values from two or more input numeric fields are merged into a single output value.In a feature class (FC) I have 4 point features that have this value for the field "Alert_Contaminant":ID Alert_Level_Contaminant1 22 23 34 3If I do a Spatial Join between this FC (join fetures) and a Grid (target), I have to choose for the join features fields, "Alert_Level_Contaminant", the Merge Rule.I choose the "mode" merge rule because I want the most frequent value. But when two value have the same frequency what value for default the overlay tool choose ?I want to that between the two values �??�??with the same frequency is chosen the one with the highest value. Is it possible ?Maybe with Python ?Someone could you help me ?
