Shapefile is not created while using the Point to Line tool. Not receiving any error, just shapefile is not being saved.
So, I am having the same problem. I have a very basic point set, I run the point to line tool, it says it is successful, no output is created. It doesn't matter if I put the output into a geodatabase or into a shape file, none of my file paths have spaces are dashes. I am not sure how to attach my data set.
Here are a few observations from my dataset. It is a CSV file. I import it into ArcGIS and create a point shapefile (WGS_1984).
As you can see the Elapsed Time is 0.00 seconds. don't know why it's not working.
Lets try a visual
I'm using ArcGIS 10.2 Advanced License.
My input file is a point shapefile.
Even though I stated a location (tried different directories) for the output file. it is not saved. There were also no errors in the session.
make sure you don't have a point selected prior to running the tool... this might give rise to...
from the help
and it makes a featureclass I believe, so you might want to check your default geodatabase incase it isn't a shapefile but an FC
Points To Line—Help | ArcGIS for Desktop
Perhaps share the Python script you're using, or a screenshot of your tool dialog. Also, what version and product are you using? More details, please.
