Sending HTTP status codes can get tricky. If you are using a JavaScript client, for JSONP callbacks to work you MUST always send a status of 200. This is why REST API sends a status code of 200 even when your request failed, but adds the actual HTTP status in a error JSON object. You can choose to do the same. Otherwise you can set a custom HTTP header using responseProperties.
JSONObject jobj = new JSONObject(); jobj.put("X-HTTP-Status", "500, An error occured when generating the image."); responseProperties[0] = jobj.toString();
responseProperties = "{ \"Content-Type\" : \"image/png\", \"X-HTTP-Status\" : \"500 - An error occurred while generating the image.\" }";
If your SOE is in .NET you will have to construct the jsonified string yourself.Essentially it would be: responseProperties = "{ \"Content-Type\" : \"image/png\", \"X-HTTP-Status\" : \"500 - An error occurred while generating the image.\" }";
RestOperation findNearFeatsOp = new RestOperation("GetImage", new string[0] , new string[] { "img" }, GetImage); .................. private byte[] GetImage(System.Collections.Specialized.NameValueCollection boundVariables, ESRI.ArcGIS.SOESupport.JsonObject operationInput, string outputFormat, string requestProperties, out string responseProperties) { responseProperties = "{\"Content-Type\" : \"image/png\",\"X-HTTP-Status\" : \"404 - Could not find the image requested.\"}"; return null; }
private byte[] GetImage(System.Collections.Specialized.NameValueCollection boundVariables, ESRI.ArcGIS.SOESupport.JsonObject operationInput, string outputFormat, string requestProperties, out string responseProperties) { try { ........ }catch(Exception e) { //Log your exception and throw it so that the REST handler intercepts your exception // and treats it as a HTTP 500. throw e; } }
