Try changing your expression variable to:expression = "round(!WSPD_SFC!/5.0, 0) * 5.0"Since the expression is quoted as a string, it will not read 'input' as a variable. It will read this as a string literal.
# Import modules import arcpy import math # Local variables: point_shp = "R:\\Tornado Research\\test\\SfcOA.shp" newfield = R_WsdpSfc input = "getclass(double(!WSPD_SFC!))" #Not sure how to get the input file in this line of code expression = "round([input]/5.0, 0) * 5.0" #Not sure if this is the correct way of doing this line # Process: Add Field arcpy.AddField_management(point_shp, newfield, "DOUBLE", "", "", "25", "", "NON_NULLABLE", "NON_REQUIRED", "") # Works fine # Execute CalculateField arcpy.CalculateField_management(point_shp, newfield, expression, "PYTHON") #Obviously this line is broken
