Hi Guys,
I am include esri maps in my application when even i am lancing my application it asking permission i am clicked Yes button After clicking map getting current position.Then some layers not loading.Could u please suggest me to fix error.Please find images
Change this line:
<link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
to:
<link rel="stylesheet" href="https://js.arcgis.com/3.20/esri/css/esri.css">
Thanks Robert,
Its working fine.
Could u please suggest me how esri maps works offline.
I am included <script src="offline.min.map.js"></script>
Hi Robert,
Thanks for replay
This is the code i am included in my application
<script src="https://js.arcgis.com/3.20"></script>
<script src="offline.min.map.js"></script> <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
console.log("Loading ArcGIS..."); require(["esri/map","esri/layers/FeatureLayer","esri/symbols/PictureMarkerSymbol","esri/graphic", "esri/SpatialReference", "esri/geometry/Point","esri/InfoTemplate", "dojo/on","dojo/domReady!"], function(Map,FeatureLayer,PictureMarkerSymbol,Graphic,SpatialReference,Point,InfoTemplate,on) { // Create map var map = new Map(""+$scope.logedinuser,{ basemap: "topo", center: [17.387140, 78.491684], zoom: 3 }); // Wait until map has loaded before starting geolocation map.on("load", startGeolocation); /*map.on("click", function (evt) { console.log(("lat/lon : " + evt.mapPoint.y + ", " + evt.mapPoint.x)); map.infoWindow.setTitle("Coordinates"); map.infoWindow.setContent("lat/lon : " + evt.mapPoint.y + ", " + evt.mapPoint.x); map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint)); });*/ // Create the marker symbol var infoTemplate = new InfoTemplate(); infoTemplate.setTitle("Equpment ${AssetID}"); infoTemplate.setContent("<b>Equpment : </b>${AssetID}<br/>" + "<b><div ><a href='#/app1/notificationadd/10002605/newhere'>Notification: </a></b><br/><br/></div>" //+ "<b>2000: </b>${POP2000:NumberFormat}<br/>" + // "<b>2000 density: </b>${POP00_SQMI:NumberFormat}" ); var markerSymbol = new PictureMarkerSymbol({ "angle":0, "xoffset":0, "yoffset":0, "type":"esriPMS", "url":"img/Location.png", "width":35, "height":35 });
function startGeolocation(){ console.log("Starting geolocation..."); var location = navigator.geolocation.getCurrentPosition(locationSuccess, locationError); /* var location = navigator.geolocation.watchPosition( locationSuccess, locationError, { maxAge: 250000, timeout: 15000, enableHighAccuracy:true } );*/ }
// Handle location success function locationSuccess(position){ //navigator.notification.alert("Came here"); if(position.coords.latitude != null || position.coords.longitude != null){ console.log("long: " + position.coords.longitude + ", lat: " + position.coords.latitude); var pointInfoTemplate = new InfoTemplate("Albuquerque"); var wgsPt = new Point(position.coords.longitude,position.coords.latitude, new SpatialReference({wkid:4326})); map.graphics.add(new Graphic(wgsPt, markerSymbol).setInfoTemplate(pointInfoTemplate)); var lineFeatureLayer = new FeatureLayer("https://services7.arcgis.com/MaZxgL04O7KLTOGI/arcgis/rest/services/Point_Assets/FeatureServer/0", { mode: FeatureLayer.MODE_SNAPSHOT, infoTemplate: infoTemplate, outFields: ["AssetID"],//here to mention display all fields id: "lineFeatureLayer" }); // var offlineEdit = new O.esri.Edit.OfflineEditBasic(); //offlineEdit.goOffline(); function initEditing() { offlineEdit.extend(lineFeatureLayer,function(success,error){ if(success){ console.log("TEST layer loaded and extended for offline use!"); } else { console.warn("Unable to load FeatureLayer!"); } }); } //var updateHandler = lineFeatureLayer.on("update-end", initEditing); console.log(lineFeatureLayer); map.addLayer(lineFeatureLayer); map.centerAndZoom(wgsPt, 7); } }
function locationError(error){ console.log("locationError code: " + error.code);
switch(error.code) { case error.PERMISSION_DENIED: alert("User denied request for geolocation."); break; case error.POSITION_UNAVAILABLE: alert("Location information is unavailable. Check application settings, make sure location permissions have been granted"); break; case error.TIMEOUT: alert( "The request to get user location timed out."); break; case error.UNKNOWN_ERROR: alert("An unknown error occurred."); break; } } } );
Gowri,
Can you post your code? What I see in the images is normal when you have forgotten to add the esri css files to your code or you have a bad url for them.
