import arcpy import os def fcs_in_workspace(workspace): arcpy.env.workspace = workspace for fc in arcpy.ListFeatureClasses(): yield os.path.join(workspace, fc) for ws in arcpy.ListWorkspaces(): for fc in fcs_in_workspace(os.path.join(workspace, ws)): yield fc for fc in fcs_in_workspace("C:/Data"): ...
fclist = list(fcs_in_workspace("C:/Data"))
Hi All,
I wanted to add to additional ways to accomplish this and apply it to different data types.
I teach Python for Esri and have had this question come up in class alot.
1. Arcpy.da.walk:
This was introduced to the data access module at 10.1 SP1
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Where this function is nice is in 2 parameters
Datatype: the value set here is the filter for what is returned as walk traverses the subfolders
type: not for all datasets, but at least you could specify point, line, poly or raster types
Look at the Sample script 1 in the documentation
2. python os.walk:
this function will perform the same type operation gathering subfolders and files
The one difference is this won't retrieve contents inside of a geodatabase.
This could be used if you script involved python code with out the use of arcpy
maybe you needed to find all the .xls files under a \projects folder.
15.1. os — Miscellaneous operating system interfaces — Python 2.7.8 documentation
Jeff
import arcpy import os def fcs_in_workspace(workspace): arcpy.env.workspace = workspace for fc in arcpy.ListFeatureClasses(): print os.path.join(workspace, fc) for ws in arcpy.ListWorkspaces(): fcs_in_workspace(os.path.join(workspace, ws)) fcs_in_workspace("C:/Data")
