Cool tool. I can explicitly run analyze, but I only want to run from the dataset level, and the only option is to itemize every fc, so if I have 100 feature datasets with 20 feature classes in most of the fd, that is a lot of selecting, especially at the last minute that I don't want to analyze 1 specific FD with its 40 sub layers. This change would need to be un selected manually. Seems like I should have the capability to just analyze at the FD level, too. Do like the idea though, at least 1 script will need to be reworked.
# set the workspace environment arcpy.env.workspace=workspace # NOTE: Analyze Datasets can accept a Python list of datasets. # Get a list of all the datasets the user has access to. # First, get all the stand alone tables, feature classes and rasters. dataList = arcpy.ListTables() + arcpy.ListFeatureClasses() + arcpy.ListRasters() # Next, for feature datasets get all of the datasets and featureclasses # from the list and add them to the master list. for dataset in arcpy.ListDatasets("","Feature"): arcpy.env.workspace = os.path.join(workspace,dataset) dataList += arcpy.ListFeatureClasses() + arcpy.ListDatasets() # reset the workspace arcpy.env.workspace = workspace
# set the workspace environment arcpy.env.workspace=workspace # The name of your feature dataset FDS = 'NameOfYourFDS' # NOTE: Analyze Datasets can accept a Python list of datasets. # Next, for feature datasets get all of the datasets and featureclasses # from the list and add them to the master list. for dataset in arcpy.ListDatasets(FDS,"Feature"): arcpy.env.workspace = os.path.join(workspace,dataset) dataList += arcpy.ListFeatureClasses() + arcpy.ListDatasets() # reset the workspace arcpy.env.workspace = workspace
