6- Verified environment below variables ORACLE_HOME = C:\app\useraccount\product\11.2.0\client_1\
Sustaining Support does not includeNew updates, fixes, security alerts, data fixes, and critical patch updatesNew tax, legal, and regulatory updatesNew upgrade scriptsCertification with new third-party products/versionsCertification with new Oracle products
Hi all:
I have a problem with arcSDE:
A)Development Workstation
Windows 2008 server Enterprise 64-bit
ArcGIS Server for Enterprise 10.1
ArcSDE 10.1 for Oracle10g
Oracle Client: 10.2.0.4
B)Database Server: (Separate server)
windows 2003 server and Oracle Database 10g Enterprise Edition Release 10.2.0.4.0
C) Sdeservice list
C:\>sdeservice -o list
SDE service Information
RDBMS: Oracle
Name: ArcSde Service(esri_sded)
SDEHOME: C:\Program Files\ArcGIS\ArcSDE\ora10gexe\
Version: 10.1
Status: SERVICE_STOPPED
What's the problem?? please help !
don't start the service SDE!
thanks!
Instead of adding to a 3-year old post, it would be better if you created a new post, referencing the other one as necessary.
It's been a long time since I responded to an application server install question, but the root cause is probably the same -- failure to use LOCAL (or TWO_TASK on Linux) as a variable instead of ORACLE_SID in the dbinit.sde file (as documented in the install instructions).
I have to recommend that you abandon Oracle 10gR2 and adopt 11gR2 as the minimum database release. ArcGIS 10.4 and beyond doesn't/won't support Oracle 10g or 11gR1 or even 11gR2 below 11.2.0.4.
- V
As Vince wrote, Double check DBINIT vairables
set SDEHOME=set ORACLE_SID=set SDEVERBOSE=TRUEsetenv TNS_ADMIN setenv TWO_TASK
