How to hide "Esri World Geocoder" in the search widght with Arcgis-js-api 3.x
Hi z xz,
Pass in empty source array to clear the default ArcGIS Online World Geocoding service:
sources: []
See this example, showing the defaults ArcGIS Online World Geocoding service:Search multiple sources | ArcGIS API for JavaScript 3.29
No you can modify the code (e.g. in CodePen) to modify the search to remove this default service:
<SPAN class="keyword token">var</SPAN> search <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Search</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> enableButtonMode<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">//this enables the search widget to display as a single button</SPAN> enableLabel<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> enableInfoWindow<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN> showInfoWindowOnSelect<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">//passing in empty source array to clear the default ArcGIS Online World Geocoding service</SPAN> sources<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"search"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Does this work for you?
Cheers,
Egge-Jan
It works,thank you!
If your issue has been solved, you may mark my answer as correct. In this way it will be clear to others - who may have the same question - that your question has been answered correctly.
