<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" /> <title>Simple Map</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map { height: 100%; } #rightPane { width: 30%; } #legendPane { border: solid #97DCF2 1px; } #bottomPane { height: 200px; } </style> <script src="http://js.arcgis.com/3.9/"></script> <script> var map; require([ "esri/map", "esri/dijit/Scalebar", "esri/dijit/OverviewMap", "esri/dijit/Legend", "esri/InfoTemplate", "esri/dijit/InfoWindowLite", "esri/layers/FeatureLayer", "dojo/parser", "dojo/dom-construct", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!", ], function ( Map, Scalebar, OverviewMap, Legend, InfoTemplate, InfoWindowLite, FeatureLayer, parser, domConstruct ) { parser.parse(); map = new Map("map", { basemap: "topo", center: [-76.869806, 39.218776], zoom: 15 }); var scalebar = new Scalebar({ map: map, scalebarUnit: "dual" }); var overviewMapDijit = new OverviewMap({ map: map, visible: true }); overviewMapDijit.startup(); map.on("layers-add-result", function (evt) { var layerInfo = arrayUtils.map(evt.layers, function (layer, index) { return { layer: layer.layer, title: layer.layer.name }; }); if (layerInfo.length > 0) { var legendDijit = new Legend({ map: map, layerInfos: layerInfo }, "legendDiv"); legendDijit.startup(); } }); var infoWindow = new InfoWindowLite(null, domConstruct.create("div", null, null, map.root)); infoWindow.startup(); map.setInfoWindow(infoWindow); var template = new InfoTemplate(); template.setTitle("<b>${Address} - ${Street}</b>"); //add a layer to the map var featureLayer = new FeatureLayer("http://arcgisserver/arcgis/rest/services/Projectfolder/Projectname/MapServer/1", { mode: FeatureLayer.MODE_ONDEMAND, infoTemplate: template, outFields: ["Pipe_Size", "Pipe_Type"] }); map.addLayer(featureLayer); map.infoWindow.resize(200, 75); }); //add the legend </script> </head> <body class="claro"> <!--[if IE 7]> <style> html, body { margin: 0; } </style> <![endif]--> <div id="content" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width: 100%; height: 100%; margin: 0;"> <div id="rightPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'"> <div data-dojo-type="dijit/layout/AccordionContainer"> <div data-dojo-type="dijit/layout/ContentPane" id="legendPane" data-dojo-props="title:'Legend', selected:true"> <div id="legendDiv"></div> </div> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="title:'Pane 2'"> This pane could contain tools or additional content </div> </div> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="overflow:hidden;"> </div> <div id="bottomPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region: 'bottom'"> <div id="grid"></div> </div> </div> </body> </html>
Re: Is it possible to convert a csv layer to an animated graphic (pulsing point)?
<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="initial-scale=1.0, width=device-width, maximum-scale=1.0, user-scalable=no">
<!-- meta tags to hide url and minimize status bar to give the web app
a native app look this only happens after app is saved to the desktop-->
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="apple-mobile-web-app-status-bar-style" content="translucent-black">
<title>Geolocation API</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
<!-- Details about the Webkit CSS Properties http://css-infos.net/properties/webkit.php
and http://www.pointabout.com/category/development-blog/pointabout-dev-help/-->
<style>
html, body #map {
height: 100%;
margin: 0px;
padding: 0px;
width: 100%;
@-webkit-keyframes
pulse
0%
opacity: 1.0;
45%
opacity: .20;
100%
@-moz-keyframes
#map_graphics_layer {
-webkit-animation-duration: 3s;
-webkit-animation-iteration-count: infinite;
-webkit-animation-name: pulse;
-moz-animation-duration: 3s;
-moz-animation-iteration-count: infinite;
-moz-animation-name: pulse;
</style>
<script src="http://js.arcgis.com/3.11/"></script>
<script>
var map, csv;
require([
"esri/map",
"esri/layers/CSVLayer",
"esri/Color",
"esri/symbols/SimpleMarkerSymbol",
"esri/renderers/SimpleRenderer",
"esri/urlUtils",
"esri/geometry/Point",
"esri/graphic",
"dojo/domReady!"
], function(
Map, CSVLayer, Color, SimpleMarkerSymbol, SimpleRenderer, InfoTemplate, urlUtils, Point, Graphic
urlUtils.addProxyRule({
proxyUrl: "/proxy/",
urlPrefix: "MYSITE.com"
basemap: "gray",
center: [ -60, -10 ],
zoom: 4
csv = new CSVLayer("http://MYSITE.com/2.5_weekz.csv", {
copyright: "Echologics"
var orangeRed = new Color([238, 69, 0, 0.5]); // hex is #ff4500
var marker = new SimpleMarkerSymbol("solid", 15, null, orangeRed);
var renderer = new SimpleRenderer(marker);
csv.setRenderer(renderer);
var template = new InfoTemplate("${type}", "${place}");
csv.setInfoTemplate(template);
map.addLayer(csv);
graphic = new Graphic(csv)
map.graphics.add(graphic);
</script>
</head>
<body>
<div id="map"></div>
</body>
</html>
