If you are going to use Python to calculate fields with lots of logic then it is much easier to use an UpdateCursor. The FieldCalculator wraps a cursor around your expression anyway so it is the same thing. I regard the FieldCalculator as a prop to use in ModelBuilder only.
The benefits of using a cursor are many:
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>feature_class<SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'A1'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">' B1'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">' A2'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'B2'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">' C'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cur<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cur<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">==</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">and</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">==</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="string token">"A AND B IDENTICAL"</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="string token">"OK"</SPAN> cur<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
if ([A1] == [B1] and [A2] == [B2]): output = "A AND B IDENTICAL" else: output = "OK"
output
